function do_rootfs failed while bitbaking
I am trying to bitbake, for i got the following error
NOTE: Out of date cache found, rebuilding...
NOTE: Handling BitBake files: \ (6657/6657) [100 %]
NOTE: Parsing finished. 0 cached, 6375 parsed, 282 skipped, 0 masked.
NOTE: Resolving any missing task queue dependencies
NOTE: preferred version git of u-boot not available (for item u-boot)
NOTE: Preparing runqueue
NOTE: Executing runqueue
NOTE: Running task 2118 of 2119 (ID: 10, /home/jars/oe/openembedded/
recipes/images/console-image.bb, do_rootfs)
ERROR: function do_rootfs failed
ERROR: see log in /home/jars/oe/tmp/work/beagleboard-angstrom-linux-
gnueabi/console-image-1.0-r0/temp/log.do_rootfs.27514
NOTE: Task failed: /home/jars/oe/tmp/work/beagleboard-angstrom-linux-
ERROR: TaskFailed event exception, aborting
ERROR: Build of /home/jars/oe/openembedded/recipes/images/console-
image.bb do_rootfs failed
ERROR: Task 10 (/home/jars/oe/openembedded/recipes/images/console-
image.bb, do_rootfs) failed
NOTE: Tasks Summary: Attempted 2117 tasks of which 2117 didn't need to
be rerun and 1 failed.
ERROR: '/home/jars/oe/openembedded/recipes/images/console-image.bb'
failed
Need some help!!!
Please provide that log, or a interpration of it.
regards,
Koen
Hi Koen,
The log is as follows
+ rm -rf /home/jars/oe/tmp/rootfs
+ mkdir -p /home/jars/oe/tmp/rootfs
+ mkdir -p /home/jars/oe/tmp/deploy/glibc/images/beagleboard
+ '[' 0 '!=' 1 ']'
+ for devtable in /home/jars/oe/openembedded/files/device_table-
minimal.txt
+ makedevs -r /home/jars/oe/tmp/rootfs -D /home/jars/oe/openembedded/
files/device_table-minimal.txt
+ rootfs_ipk_do_rootfs
+ set -x
+ package_update_index_ipk
+ set -x
+ ipkgarchs='all any noarch arm armv4 armv4t armv5te armv6 armv7
armv7a beagleboard'
+ '[' '!' -z '' ']'
+ touch /home/jars/oe/tmp/deploy/glibc/ipk/Packages
+ ipkg-make-index -r /home/jars/oe/tmp/deploy/glibc/ipk/Packages -p /
home/jars/oe/tmp/deploy/glibc/ipk/Packages -l /home/jars/oe/tmp/deploy/
glibc/ipk/Packages.filelist -m /home/jars/oe/tmp/deploy/glibc/ipk
/home/jars/oe/tmp/staging/i686-linux/usr/bin/ipkg.py:39:
DeprecationWarning: the md5 module is deprecated; use hashlib instead
  import md5
+ for arch in '$ipkgarchs'
+ '[' -e /home/jars/oe/tmp/deploy/glibc/ipk/all/ ']'
+ touch /home/jars/oe/tmp/deploy/glibc/ipk/all/Packages
+ ipkg-make-index -r /home/jars/oe/tmp/deploy/glibc/ipk/all/Packages -
p /home/jars/oe/tmp/deploy/glibc/ipk/all/Packages -l /home/jars/oe/tmp/
deploy/glibc/ipk/all/Packages.filelist -m /home/jars/oe/tmp/deploy/
glibc/ipk/all/
  import md5
Traceback (most recent call last):
  File "/home/jars/oe/tmp/staging/i686-linux/usr/bin/ipkg-make-index",
line 114, in <module>
    pkg = ipkg.Package(filename)
  File "/home/jars/oe/tmp/staging/i686-linux/usr/bin/ipkg.py", line
162, in __init__
    tarf = tarfile.open("control.tar.gz", "r", tarStream)
  File "/home/jars/oe/tmp/staging/i686-linux//usr/lib/python2.6/
tarfile.py", line 1649, in open
    raise ReadError("file could not be opened successfully")
tarfile.ReadError: file could not be opened successfully
Pramod
