The host is BBB RevC running the Debian distribution dated May 14, 2014 (Wheezy)
I am trying to cross compile C code for the host.
I am running the GCC cross compiler (arm-linux-gnueabihf) inside Eclipse under Ubuntu 14.04 on Intel 64 bit machine.
[Basically the Derek Molloy recommended environment]
It seems that the BBB Debian (Wheezy) release comes with glibc-2.13
It seems that GCC cross tool chain comes with glibc-2.19
As long as I compile simple (not useful) programs, things compile and run.
As soon as I start to do usefully complex programming, I get run time errors
saying that glibc-2.15 is required.
What is the best way out of this road-block?
Is there an earlier version of the GCC cross compiler that uses glib-2.13?
Can I force the current GCC cross compiler to link to armhf glib-2.13?
Can I update the BBB Debian Wheezy to glibc-2.19 without breaking
other things in the distribution? Normal attempts at updating say
2.13 is the latest.
I saw an earlier thread talking about loading an experimental glibc-2.18 on the BBB.
What are the (any bad?) side effects of that.
Can you be more specific when referring to "run time errors " ?
I pretty much did the exact thing you’ve mentioned as far as I can tell, but am using Lubuntu 14.04. A simple hello world app compiled and ran fine, but I have not tested anything more extensive.
The successfully/clean compiled binary named LM is located at
/home/debian/bin
root@BBB3:/home/debian/bin# ./LM ./LM: /lib/arm-linux-gnueabihf/libc.so.6: version `GLIBC_2.15’ not found (required by ./LM) root@BBB3:/home/debian/bin#
Upon a command to run it, the error message above is displayed, and the run aborts.
Hello_World runs fine. Simple I/O programs run fine.
Apparently my more complex programs use functionality introduced in 2.15 and later and there is no
way to run them on the stable Debian 7 (Wheezy) distribution.
I have since discovered that Debian 8 (Jessie) comes with glibc 2.19.
There is a “test” version of Jessie on the elinux.org website. I will try that.
The problem is that Debian 8 is not yet frozen, and has no announced
release date that I can find, which means that it more than 6 months
away. Probably a year.
Debian is currently multiple years behind the GCC compiler.
The previous Beaglebone Angstrom release came with glibc 2.16 which would
probably also run this specific compiled code. But I have run across other
BBB users that get a similar message, asking for glibc_2.17. So, it
/home/debian/bin
./LM: /lib/arm-linux-gnueabihf/libc.so.6: version `GLIBC_2.15' not found
(required by ./LM)
I do have a script here to generate an x86 cross compiler, that
matches glibc/gcc on the wheezy image..
however you have to run it on a wheezy/x86 machine..
aborts.
There is a "test" version of Jessie on the elinux.org website. I will try
that.
Well the freeze is the 5th of Nov, and only bug fixes will be allowed
till it is released.
I was aware of your cross-compiler, but would prefer to remain consistent with all of our other development environments.
Switching to the “test” version of jessie on the elinux.org website eliminated my glibc problems.
Now I need to get to debugging the code. It runs on a Davinci, but now I need to get it running on the Sitara/Beaglebone.
I am interested in the “cross-gcc-defaults” for jessie, but am getting a “404 Not Found” at that url. It must have been moved recently, since Google also shows it at that location.
