On 16/05/2012 19:13, John (USP) wrote:
**From:**`` [beagleboard@googlegroups.com](mailto:beagleboard@googlegroups.com) [[mailto:beagleboard@googlegroups.com](mailto:beagleboard@googlegroups.com)] **On Behalf Of** rahim panahi
**Sent:**`` Wednesday, May 16, 2012 2:58 AM
**To:**`` [beagleboard@googlegroups.com](mailto:beagleboard@googlegroups.com)
**Subject:**`` [beagleboard] gcc & g++
Hi all
I've downloaded a toolchain containing gcc and g++ in it , after installing angstrom from narcissus I've tried to compile the toolchain so
as I've read from somepages in internet I went to this folder
/usr/local/angstrom/arm and entered the following command
sh ./environment-setup
but nothing happend and just the command line jumped to another line as below :
>>root@beagleboard:/usr/local/angstrom/arm# sh ./environment-setup
`and I thought that gcc and g++ were installed by this command so I ran this code to compile my opencv example to see if I can see a simple image` `histogram or not` `>>root@beagleboard:/# g++ -o Hist Hist.cpp `pkg-config --libs opencv` `pkg-config --cflags opencv
but the output was :
>> sh: g++: not found
The arm cross compiler command would be arm-angstrom-linux-gnueabi-g++ or arm-angstrom-linux-gnueabi-gcc
John
I'm sure that my toolchain contains gcc and g++ because I searched the arm folder and found them , but I think that they are not installed .
`any suggestion about this problem(my compile command is wrong or …) ?```
If you see gcc and g++ in your toolchain, they are probably linked to the files I mentioned above. I would recommend that you use the full name as the native compiler uses gcc and g++ so you will end up with x86 code and not arm code. Just make sure the compiler bin folder is in your PATH.
John
-- To join: [http://beagleboard.org/discuss](http://beagleboard.org/discuss)
To unsubscribe from this group, send email to:
[beagleboard+unsubscribe@googlegroups.com](mailto:beagleboard+unsubscribe@googlegroups.com)
Frequently asked questions: [http://beagleboard.org/faq](http://beagleboard.org/faq)
Whoops! My mistake, it is indeed pre-fixed - not post-fixed as I earlier stated! *`` arm-angstrom-linux-gnueabi-g++* is correct.
– To join: http://beagleboard.org/discuss
Frequently asked questions: http://beagleboard.org/faq
