I am trying to install geexbox on Beagleboard-xm rev c. I followed the
link mentiond below to obtain Geexbox distribution.
http://labs.igep.es/index.php/How_to_get_the_Geexbox_distribution
The problem is when I try to build the distribution with make command
I get the following errors
tenet8@tenet8-desktop:~/geexbox$ make
scripts/checkdeps build
scripts/rootfs
INSTALL opkg
BUILD opkg
INSTALLDEV curl
PACKAGEDEV curl
GET curl
-e
Cant't get curl sources : http://curl.online-mirror.de/download/curl-7.20.1.tar.bz2
Try later !!
make: *** [rootfs] Error 1
Please help me
Why don't you just use angstrom and install enna, that works much better on a beagleboard
Can you suggest me any links regarding regarding the same.
Jyothi wrote:
> Hi,
http://www.google.com/search?q=installing+angstrom
I tried installing enna on angstrom using the command
opkg install enna
When i type enna in the terminal I get the following error
root@beagleboard:~# enna
enna: error while loading shared libraries: libecore_ipc-ver-pre-
svn-05.so.0: Cannot open shared object file: No such file or
directory.
Please suggest me any solution.
