General Question (off-topic)
HI all,
I have two questions but it’s not based on beagleboard architecture and hope you allow me to post this.
  1. I have 64MB of Nand flash with erase block of 16KiB. I created an jffs2 image
    with pagesize of 0x200. After I put the image on nandflash using nandwrite and booted it.
    I got these message:
jffs2: Erase block size too small (16KiB). Using virtual blocks size (32KiB) instead
Then, I tried to create another jffs2 image with 32KiB of eraseblock and pass --blockalign=2.
But, I got same messages.
Do you know how to fix it?.
  1. This is regarding with u-boot. Is there a way to access whatever defined u-boot environment or read the u-boot block0
    from linux userspace?.
    I am looking for a different solution and I cannot use the kernel argument to pass the u-boot environment then,
parse the /proc/cmdline to get the data that I need.
Any idea?
John
HI all,
I have two questions but it's not based on beagleboard architecture and hope
and booted it.
instead
2. This is regarding with u-boot. Is there a way to access whatever defined
Any idea?
With most builds of the linux kernel for Beagle, /dev/mtdX and
/dev/mtdblockX would have the contents of the NAND flash (which you
must have been accessing for your JFFS2 manipulations). The u-boot
project generates an application that can be used to read the u-boot
environment variables (fw_printenv). It is covered in the BeagleBoard
101 materials on ESC Build Your Own Embedded System online registration deadline 3/25 - BeagleBoard. Recommend you use Google
or search this mailing list to find more.
Jason,
Thanks for the response. I saw the utility and using it.
But, I got an error “Bad CRC, using default environment” when I execute the fw_printenv
any idea how to fix it?
-john
