I now get console output, but I can't mount the root partition r/w on
mmcblk0p2. There are pre-compiled OE kernels that can mount this
partition and read from/write to it, but mine can't. I can't figure out
whether I should be investigating an mmc problem or a usb problem.
I've tried the unpatched linux-omap kernel (2.6.37) and the
gentoo-sources kernel (2.6.36) and the patched linux-omap kernel
(2.6.29).
The error I get with unpatched linux-omap 2.6.37 is...
Waiting for root device /dev/mmcblk0p2...
mmc0: error -110 whilst initialising SD card
Google comes up with nothing that looks relevant.
The full dmesg output is...
OMAP3 beagleboard.org # setenv console ttyO2,115200n8
OMAP3 beagleboard.org # setenv mpurate 800
OMAP3 beagleboard.org # run mmcargs
OMAP3 beagleboard.org # mmc init
mmc1 is available
OMAP3 beagleboard.org # fatload mmc 0:1 0x80300000 uOMAP
reading uOMAP
2660912 bytes read
OMAP3 beagleboard.org # bootm 0x80300000
## Booting kernel from Legacy Image at 80300000 ...
Image Name: Linux-2.6.37-rc7+
Data Size: 2660848 Bytes = 2.5 MB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Linux version 2.6.37-rc7+ (root@puppy) (gcc version 4.4.2 (Gentoo 4.4.2
p1.0) )
#4 PREEMPT Wed Dec 29 10:29:20 UTC 2010
CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: OMAP3 Beagle Board
Memory policy: ECC disabled, Data cache writeback
OMAP3630 ES1.1 (l2cache iva sgx neon isp 192mhz_clk )
SRAM: Mapped pa 0x40200000 to va 0xfe400000 size: 0x10000
pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
pcpu-alloc: [0] 0
Built 1 zonelists in Zone order, mobility grouping on. Total pages:
130048
Kernel command line: console=ttyO2,115200n8 mpurate=800 buddy=none
camera=lbcm3m
1 vram=12M omapfb.mode=dvi:640x480MR-16@60 omapdss.def_disp=dvi
root=/dev/mmcblk
0p2 rw rootfstype=ext3 rootwait
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 512MB = 512MB total
Memory: 514436k/514436k available, 9852k reserved, 0K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
vmalloc : 0xe0800000 - 0xf8000000 ( 376 MB)
lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
modules : 0xbf000000 - 0xc0000000 ( 16 MB)
.init : 0xc0008000 - 0xc002e000 ( 152 kB)
.text : 0xc002e000 - 0xc04dd550 (4798 kB)
.data : 0xc04de000 - 0xc0517000 ( 228 kB)
SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:402
Clocking rate (Crystal/Core/MPU): 26.0/332/600 MHz
Reprogramming SDRC clock to 332000000 Hz
GPMC revision 5.0
IRQ: Found an INTC at 0xfa200000 (revision 4.0) with 96 interrupts
Total of 96 interrupts on 1 active controller
OMAP clockevent source: GPTIMER12 at 32768 Hz
Console: colour dummy device 80x30
Calibrating delay loop... 513.62 BogoMIPS (lpj=2007040)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
regulator: core version 0.5
regulator: dummy:
NET: Registered protocol family 16
OMAP GPIO hardware version 2.5
omap_mux_init: Add partition: #1: core, flags: 0
OMAP3 Beagle Rev: xM
Found NAND on CS0
Registering NAND on CS0
Unable to get DVI reset GPIO
Switched to new clocking rate (Crystal/Core/MPU): 26.0/332/800 MHz
OMAP DMA hardware revision 5.0
bio: create slab <bio-0> at 0
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
omap_device: omap_i2c.1: new worst case activate latency 0: 30517
omap_i2c omap_i2c.1: bus 1 rev4.0 at 2600 kHz
twl4030: PIH (irq 7) chaining IRQs 368..375
twl4030: power (irq 373) chaining IRQs 376..383
twl4030: gpio (irq 368) chaining IRQs 384..401
regulator: VUSB1V5: 1500 mV normal standby
regulator: VUSB1V8: 1800 mV normal standby
regulator: VUSB3V1: 3100 mV normal standby
twl4030_usb twl4030_usb: Initialized TWL4030 USB module
regulator: VMMC1: 1850 <--> 3150 mV at 3000 mV normal standby
regulator: VDAC: 1800 mV normal standby
regulator: VDVI: 1800 mV normal standby
regulator: VSIM: 1800 <--> 3000 mV at 1800 mV normal standby
omap_i2c omap_i2c.3: bus 3 rev4.0 at 100 kHz
Advanced Linux Sound Architecture Driver Version 1.0.23.
Switching to clocksource 32k_counter
musb_hdrc: version 6.0, musb-dma, otg (peripheral+host), debug=0
omap_device: omap_i2c.1: new worst case deactivate latency 0: 30517
musb_hdrc musb_hdrc: USB OTG mode controller at fa0ab000 using DMA, IRQ
92
NET: Registered protocol family 2
IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
TCP established hash table entries: 16384 (order: 5, 131072 bytes)
TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 16384 bind 16384)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
DLM (built Dec 29 2010 05:29:59) installed
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
msgmni has been set to 1004
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
omap_uart.0: ttyO0 at MMIO 0x4806a000 (irq = 72) is a OMAP UART0
omap_uart.1: ttyO1 at MMIO 0x4806c000 (irq = 73) is a OMAP UART1
omap_uart.2: ttyO2 at MMIO 0x49020000 (irq = 74) is a OMAP UART2
console [ttyO2] enabled
omap_uart.3: ttyO3 at MMIO 0x49042000 (irq = 80) is a OMAP UART3
brd: module loaded
loop: module loaded
omap2-nand driver initializing
No NAND device found.
usbcore: registered new interface driver smsc95xx
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 1
ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: OMAP-EHCI Host Controller
usb usb1: Manufacturer: Linux 2.6.37-rc7+ ehci_hcd
usb usb1: SerialNumber: ehci-omap.0
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 3 ports detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
usbcore: registered new interface driver cdc_acm
cdc_acm: v0.26:USB Abstract Control Model driver for USB modems and ISDN
adapter
s
usbcore: registered new interface driver usblp
usbcore: registered new interface driver usbtmc
usbcore: registered new interface driver libusual
zero gadget: Gadget Zero, version: Cinco de Mayo 2008
zero gadget: zero ready
musb_hdrc musb_hdrc: MUSB HDRC host driver
musb_hdrc musb_hdrc: new USB bus registered, assigned bus number 2
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: MUSB HDRC host driver
usb usb2: Manufacturer: Linux 2.6.37-rc7+ musb-hcd
usb usb2: SerialNumber: musb_hdrc
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
mice: PS/2 mouse device common for all mice
twl_rtc twl_rtc: rtc core: registered twl_rtc as rtc0
twl_rtc twl_rtc: Power up reset detected.
twl_rtc twl_rtc: Enabling TWL-RTC.
OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
usbcore: registered new interface driver ushc
omap_sham_mod_init: loading omap-sham driver
omap_sham_mod_init: Unsupported cpu
omap_aes_mod_init: loading omap-aes driver
omap_aes_mod_init: Unsupported cpu
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
usbcore: registered new interface driver snd-usb-audio
usbcore: registered new interface driver snd-ua101
usbcore: registered new interface driver snd-usb-caiaq
OMAP3 Beagle/Devkit8000 SoC init
asoc: twl4030-hifi <-> omap-mcbsp-dai.1 mapping ok
ALSA device list:
#0: omap3beagle
IPv4 over IPv4 tunneling driver
hub 1-0:1.0: unable to enumerate USB device on port 2
GRE over IPv4 demultiplexor driver
TCP cubic registered
NET: Registered protocol family 17
802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
All bugs added by David S. Miller <davem@redhat.com>
sctp: Hash tables configured (established 16384 bind 32768)
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
omap2_set_init_voltage: unable to find boot up OPP for vdd_mpu
omap2_set_init_voltage: Unable to put vdd_mpu to its init voltage
Power Management for TI OMAP3.
clock: disabling unused clocks to save power
registered taskstats version 1
regulator_init_complete: incomplete constraints, leaving VDVI on
regulator_init_complete: incomplete constraints, leaving VDAC on
twl_rtc twl_rtc: setting system clock to 2000-01-01 00:00:00 UTC
(946684800)
I'd certainly appreciate any help you can give
Many thanks
Alan
