getting ECC failed error when booting up
Hello guys,
My BB loaded with angstrom suddenly started giving an error as below.
It is not booting anymore. Any idea what went wrong, plz help.
Texas Instruments X-Loader 1.5.1 (Jul 20 2011 - 09:50:57)
Beagle Rev C1/C2/C3
Reading boot sector
Loading u-boot.bin from nand
ECC Failed, page 0x00080000
14 f0 9f e5 14 f0 9f e5 14 f0 9f e5 14 f0 9f e5 14 f0 9f e5 14 f0 9f
e5 14 f0 9f e5 14 f0 9f e5 40 82 0 80 40 82 0 80 0 83 0 80 0 83 0 80
c0 83 0 80 c0 83 0
Devanand T
It is stuck at there...... Please help me.
Hello guys,
same answer as on IRC, correctly prepare an sd card and boot from it,
then either rase the nand or copy the needed files to it.
I did so , still it is not working
You obviously did not - if you have a proper SD image, the NAND is not used.
the only difference between normal boot and sd card boot (holding the
user button) is tha date of the x-loader:
normal boot: Texas Instruments X-Loader 1.5.1 (Jul 20 2011 - 09:50:57)
sd card boot: Texas Instruments X-Loader 1.4.4ss (Aug 19 2010 -
02:49:27)
i'm using validation image:
beagleboard-validation-201008201549.img.gz
i saw a similar case here
http://markmail.org/message/tacnzfdbaerpuebw#query:+page:1+mid:bgf3qrcsqvsynf47+state:results
On the old, Bx/Cx beagle's the SYSBOOT lines are setup to boot the
NAND before the SD card..
Holding the user button on these older beagle's forces the SD card before NAND..
(the beagle xM's default to SD, but need to read the USER button
status to do the alternate boot..)
Hi Devanand,
i also facing the same issue now…have you find any solution reg…
kindly guide me to solve the issue.
Thanks & Regards
Venkatesh S
9843968630
Well if you are still using "X-Loader" this is entirely your fault...
Since everyone should have moved from X-Loader years ago, kindly show
us your "actual" issue..
Thank you for your reply…
i paste below my issue.
X-Loader 1.41
0 0 0 60 0 60 0 60 0 60 0 60 0 60 0 60 0 60 0 60 0 60 0 60 0 60 0 60 0 60 0 60 40 0 60 0 20 0 60 0 0 0 60 0 60 0 60 0 40 0 60 0 20 0 60 0 0 0 60 0 60 40 20 0 0 0 60 0 0 0 60 0 0 0 60 0 60 60 60 0 0 0 0 60 0 0 40 60 40 0 0 60 0 60 20 60 60 0 40 60 0 0 0 60 40 20 20 60 0 20 0 60 0 0 20 60 0 20 20 60 0 0 0 60 20 20 20 60 0 0 0 60 60 0 20 60 60 0 20 60 0 0 40 60 60 60 60 0 0 40 0 60 0 0 0 60 20 0 40 60 60 0 0 60 0 0 40 60 0 0 0 0 60 20 0 60 60 20 0 60 0 20 40 60 0 20 0 60 60 0 20 60 60 0 20 60 0 0 40 60 60 60 60 40 0 0 0 60 0 0 40 60 0 0 40 60 0 40 40 60 0 40 40 60 20 0 0 60 20 0 0 60 0 20 20 60 0 20 0 60 0 0 40 60 0 0 0 60 60 60 60 0 0 60 0 60
Thanks & Regards
Venkatesh S
