Yes you can change the parameters of the ADC. When alsamixer starts up , it only displays the playback parameters.
Have a look on the top left of the screen and you should see the settings “Playback” , “Capture” and “all”.
Use the tab key to select “Capture” and then search for the “TX1 Digital” control.
