I've just started with the Beagleboard, and I'm working on getting my
dev environment set up. The wiki is very useful, and I plan to use
openembedded, as that seems like the easiest way to go. Following the
setup instructions here:
http://elinux.org/BeagleBoardAndOpenEmbeddedGit
it looks like bitbake will build the entire toolchain, including a gcc
ARM crosscompiler, is that correct? If I use openembedded, do I need
the CodeSourcery toolchain? Is there any benefit to using
CodeSourcery, even if I don't require it? I see it is "recommended",
as per http://elinux.org/BeagleBoard#Compiler , but I'm not sure if
that means I need it if I'm using openembedded.
Thanks for any help you can give me.
Brett
