GigE-Adapter
is there a goog GigE-USB-adapter one can recommend for the beagle?
Bye - Robert
How were you planning to funnel 1000Mbit/s ethernet through a ~450Mbit/
s usb?
regards,
Koen
I do not need the 1000Mbit/s but more than 100. The 480MBits/s for USB 2.0 are enough.
2008/10/2 Koen Kooi <koen.kooi@gmail.com>
How were you planning to funnel 1000Mbit/s ethernet through a ~450Mbit/s
usb?
Your usb does 450Mbps? I've never seen usb get anywhere close to that.
Robert Kuhn wrote:
> Hello,
usb?
are enough.
USB struggles to keep up with 100Mbps ethernet, so I doubt you'd gain
anything from trying to shove 1000Mbps through it. Quite possibly it
would even get worse.
Hi Måns,
okay, I never tested ethernet over USB. It was just a thought.
Bye - Robert
2008/10/2 Måns Rullgård <mans@mansr.com>
It has been my experience that you don’t have enough CPU.
In the PowerPC world it takes more that a Megahertz of CPU clock rate to do a Megabit - even with Jumbo (9000 byte) packets:
10 MHz for 10baseT
100 MHz for 100baseT
1 GHz for 1000baseT
The USB Ethernet gadget seemed to do quite well actually.
