Hello!
I put a Narcissus build on my SD card with the following:
Current configuration:
Machine: beagleboard
Image type: tbz2
Additional Packages:
angstrom-gpe-task-base
angstrom-task-gnome
angstrom-x11-base-depends
bash
e-wm
e-wm-config-default
e-wm-config-standard
shadow
Preconfiguring image
Installing packages:
task-base
udev
angstrom-version
tinylogin
initscripts
sysvinit
sysvinit-pidof
e-wm
e-wm-config-default
angstrom-task-gnome
shadow
bash
Assembling image
When I login to ether root or the account that I created through the
GUI on the first boot, I get the window that lets me set the country
and the time zone, and then I get a window that says something along
the lines of 'Welcome to GPE! I have set up some stuff for you in the
panel at the bottom of the screen. Click the empty spots to add or
remove things'.
I also am able to see the (I believe that it is GNOME) green leaf-like
background image, but after pressing OK on the welcome screen, no
panel appears at the bottom.
I have my mouse arrow, but clicking doesn’t do anything, and there are
no panels or any display of the partitions on the SD card like there
were when I used Koen's Angstrom demo files from
http://www.angstrom-distribution.org/demo/beagleboard/
I am guessing that this means that the windows manager is not started/
Enlightenment is not running?
I tried using the serial connection through HyperTerminal (because I
can’t get to a terminal through the GUI) to start up Enlightenment.
These were my results:
The Angstrom Distribution beagleboard ttyS2
Angstrom 2010.7-test-20100731 beagleboard ttyS2
beagleboard login: root
root@beagleboard:~# enlightenment_start
E - PID=1423, do_precache=0, valgrind=0
ESTART: 0.00003 [0.00003] - begin
ESTART: 0.00149 [0.00146] - signals done
ESTART: 0.01279 [0.01129] - determine prefix
DYNAMIC DETERMINED PREFIX: /usr
ESTART: 0.03769 [0.02490] - prefix done
ESTART: 0.03827 [0.00058] - eina init
ESTART: 0.04120 [0.00293] - intl init
ESTART: 0.04163 [0.00043] - parse args
ESTART: 0.04169 [0.00006] - arg parse done
ESTART: 0.04184 [0.00015] - ecore init
ESTART: 0.06888 [0.02704] - ecore_file init
ESTART: 0.07135 [0.00247] - more ecore
ESTART: 0.07159 [0.00024] - x connect
<<<< Enlightenment Error >>>>
Enlightenment cannot initialize its X connection.
Have you set your DISPLAY variable?
E17: Begin shutdown procedure!
ESTART: 0.00107 [0.00104] - signals done
ESTART: 0.00153 [0.00046] - determine prefix
ESTART: 0.00388 [0.00235] - prefix done
ESTART: 0.00424 [0.00037] - eina init
ESTART: 0.00680 [0.00256] - intl init
ESTART: 0.00723 [0.00043] - parse args
ESTART: 0.00729 [0.00006] - arg parse done
ESTART: 0.00742 [0.00012] - ecore init
ESTART: 0.02106 [0.01364] - ecore_file init
ESTART: 0.02350 [0.00244] - more ecore
ESTART: 0.02374 [0.00024] - x connect
root@beagleboard:~# startx
hostname: beagleboard: Unknown host
/usr/bin/startx: line 183: /OE/angstrom-dev/sysroots/x86_64-linux/usr/
bin/mcooki
e: not found
Couldn't create cookie
If anyone has any ideas, or if I am heading down the wrong path with
my windows manager lead, any help is greatly appreciated!
