is there a decent canadian supplier for BB-related goodies? things
like cases, cables, adapters, that sort of thing?
rday
rday
Hi Robert,
Any hobby electronics store should carry some boxes if you want to keep the board safe. You could also pick up a plexiglass sheet (from Home Depot), cut it to size, drill holes through and used some screws with bolts to keep the board in place between the sheets. This was my quick and dirty solution for a box/case. For cables and other stuff, check out Active (http://www.active123.com).
Hope this helps,
Utku
