I followed the PinMux wiki to enable the GPIOs, i.e. GPIO-168.
http://elinux.org/BeagleBoardPinMux#U-Boot
it seems the gpio-168 is set to M4 in the default u-boot config.
According to the previous link, in the kernel setup, the
CONFIG_OMAP_MUX has to be enable. But when the CONFIG_OMAP_MUX is
enabled, my kernel won't find the root file system anymore. Error
message is shown at the bottom.
Another question is related to the mux.c file. The gpio-168 is AF15.
The default mux.c file is set to MODE0. Without enable the OMAP_MUX,
if I change mux.c to MODE4, will that enable the gpio-168?
Thanks a lot.
MUX_CFG_34XX("AF15_34XX_I2C2_SCL", 0x1be,
OMAP34XX_MUX_MODE0 | OMAP34XX_PIN_INPUT_PULLUP)
Error message:
[ 317.434753] fbcvt: 1024x768@60: CVT Name - .786M3-R
[ 317.470184] Console: switching to colour frame buffer device 128x48
[ 317.490936] clock: clksel_round_rate_div: dpll4_m4_ck target_rate 48000000
[ 317.497863] clock: new_div = 9, new_rate = 48000000
[ 317.511779] Waiting for root device /dev/mmcblk0p2...
[ 318.064971] mmc0: new high speed SDHC card at address 1234
[ 318.071166] mmcblk0: mmc0:1234 SA08G 7.40 GiB (ro)
[ 318.076293] mmcblk0: p1 p2
[ 318.166931] VFS: Cannot open root device "mmcblk0p2" or unknown-block(179,2)
[ 318.174041] Please append a correct "root=" boot option; here are
the available partitions:
[ 318.182525] 1f00 512 mtdblock0 (driver?)
[ 318.187530] 1f01 1920 mtdblock1 (driver?)
[ 318.192565] 1f02 128 mtdblock2 (driver?)
[ 318.197570] 1f03 4096 mtdblock3 (driver?)
[ 318.202606] 1f04 255488 mtdblock4 (driver?)
[ 318.207641] b300 7763968 mmcblk0 driver: mmcblk
[ 318.212890] b301 329301 mmcblk0p1
[ 318.217224] b302 7430062 mmcblk0p2
[ 318.221588] Kernel panic - not syncing: VFS: Unable to mount root fs
on unknown-block(179,2)
