GPIO Default PU/PD/Drive conditions?
So after I had a nice PCB all laid out and routed I was looking at some of the GPIO I was planning to use with a voltmeter and noticed I had a lot of problems. These problems took the form of some GPIO being pulled up or down at power-up in opposition to the control signals I was planning.
1.) One case was P9_15 where the bootup condition is 1.6V??? That would hold my signal right smack in no-mans-land between high and low. Looking at the schematic I see that pin is in tug-of-war with another one that is not on the headers so I don’t understand the intention there.
2.) In another case the pin I selected was pulled low which means I would be putting invalid data on an output buffer because the /OE line is pulled low at power on unless my external pull-up was extremely strong.
3.) The worst case I found however, was the LCD control signals shared with GPIO (P8_27 - P8_30). LCD_DE and LCD_HSYNC are both driven low at boot and my design originally had those setup as BBB Inputs that would be fed from an external buffer. The moment that /SYS_RESETn went high, those buffers would be enabled and driving their outputs as well. If there is a conflict then I have a clear contention issue that could zap one or the other part. I discovered this when connecting those pins to a pull-up had no effect on the output voltage. Where they simply pulled low then my pull-up would have created a voltage divider and raised the voltage at that pin.
Is there anything that lists the pins and the default logic state that’s on them when the device boots? I also didn’t see anything that mentioned the SRM about being wary of LCD_HSYNC and LCD_DE being driven low. I looked at the schematic and there is a resistor shown on each of those signals but no indication of the value. Is that to protect from contention? If the HDMI framer is disabled should/will those pins remain driven?
The data manual lists the default state of the pins at power up. That is the first thing I would look at as there is nothing you can do to change those…Be careful on the LCD pins as those are also the boot pins.
http://www.ti.com/product/am3359
After that, you can change the default setting from the SW by crating your own DTS file.
You want the actual data sheet for the AM335x. Chapter 2 "Terminal
Descriptions" lists the pin state during and after reset, as well as I/O
buffer details (drive strength, pull up/down capability, hysteresis,
etc) for each package pin. You still have to refer to the BeagleBone
schematic for some things (like your two pins tied together, or external
pull up/down resistors as used on the LCD/boot pins).
http://www.ti.com/lit/gpn/am3359
