GPIO Device tree BeagleBone AI, 4.19 Kernel image
Hi all,
In the last few days, I’ve been working on updating my device tree files to be compatible with the 4.19 kernel image:
https://rcn-ee.net/rootfs/bb.org/testing/2020-09-07/buster-iot/am57xx-debian-10.5-iot-armhf-2020-09-07-4gb.img.xz
using the device tree files at:
https://github.com/beagleboard/BeagleBoard-DeviceTrees/tree/v4.19.x-ti-overlays/src/arm/overlays
I haven’t been able to figure out how to properly set the default values (on or off) of my gpios on bootup. in bbai-bone-buses.dtsi, I found the group “leds” and thought I could configure these pins in a similar fashion to the older am5729-beagleboneai-roboticscape.dts. However, I’ve only been able to set the pins as gpios, and not choose whether they output on or off at boot. Here is my dts:
/dts-v1/;
/plugin/;
* Helper to show loaded overlays under: /proc/device-tree/chosen/overlays/
&{/chosen} {
overlays {
VENTION-GPIO = TIMESTAMP;
&ocp {
P8_11_pinmux { pinctrl-0 = <&P8_11_gpio_pin>; }; /* /
P8_13_pinmux { pinctrl-0 = <&P8_13_gpio_pin>; }; /
P8_14_pinmux { pinctrl-0 = <&P8_14_gpio_pin>; }; /* /
P8_15_pinmux { pinctrl-0 = <&P8_15_gpio_pin>; }; /
P9_15_pinmux { pinctrl-0 = <&P9_15_gpio_pin>; }; /
P8_16_pinmux { pinctrl-0 = <&P8_16_gpio_pin>; }; /
P8_17_pinmux { pinctrl-0 = <&P8_17_gpio_pin>; }; /
P8_19_pinmux { pinctrl-0 = <&P8_19_gpio_pin>; }; /
P9_12_pinmux { pinctrl-0 = <&P9_12_gpio_pin>; }; /
P9_14_pinmux { pinctrl-0 = <&P9_14_gpio_pin>; }; /
&leds{
pinctrl-names = “default”;
compatible = “gpio-leds”;
led_P8_11{
status=“enabled” ;
default-state=“on”;
I would eventually like to configure the default state of all of these pins.This dts compiles, but will brick my device. Any ideas about how I can set the boot states with this framework?
Doug
Hi all,
After a lot of head-scratching, I figured out the proper syntax. The following dts will configure P8_19 as a LED pin with a default state of “on”:
/dts-v1/;
/plugin/;
&{/chosen} {
overlays {
GPIO_CUSTOM = TIMESTAMP;
&ocp {
leds {
led_P8_19 {
status = “okay”;
label = “MY_GPIO”;
default-state = “on”;
Hopefully this will help out future head-scratchers!
