gpio interrupt of omap beagle board
I put the Ethernet network device on Omap beagle board, which runs
Linux 2.6.22.18.
I want to use GPIO 17 as an interrupt source from the network device.
I added the code in probe function of the network device as
followings;
ks8851_probe()
#define GPIO17 17
        u32 irq;
        omap_request_gpio( GPIO17 );
        irq = gpio_to_irq( GPIO17 );
        gpio_direction_input( GPIO17 );
        request_irq(lp->irq,
ks8851_interrupt,IRQF_TRIGGER_LOW,"ks8851isr", dev);
        (omitted)
After compile the Linux kernel including the code above, I loaded the
new kernel on the omap beagle board.
When the kenel starts to work, there is endless interrupt
Rdx,
David J. Choi
2.6.22 is so 3 years ago
Hello Koen,
I am sorry for late response but I have been out-of country until yesterday.
I have the omap beagle board source tree. But I can not catch you. Please give me more detail information.
Again sorry and thank you for your help in advance.
David J. Choi
2009/8/17 Koen Kooi <koen@beagleboard.org>
Hello Koen,
Last night, I found the solution. Here is my solution.
ks8851_probe()
#define GPIO17 17
#define CONTROL_PADCONF_ETK_D2 (void __iomem *)0x480025E0
u32 u,irq;
u32 u;
//set GPIO 17 as a input, GPIO_17 is bit 17 in the register
//Set PAD pull up/down enable, pull up mode for GPIO17, input enable
u=__raw_readl(IO_ADDRESS(CONTROL_PADCONF_ETK_D2));
u= u & (~(0x7<<16)); //clean bit 16,17,18
u = u | (0x04<<16); // set mode 4
u = u | ( 0x100 << 16 ); //input enable
__raw_writel(u,IO_ADDRESS(CONTROL_PADCONF_ETK_D2));
irq = gpio_to_irq( GPIO17 ); //
request_irq(irq,ks8851_interrupt,IRQF_TRIGGER_LOW,“ks8851isr”, dev); //LOW Level trigger
(omitted)
David J. Choi
    u=\_\_raw\_readl\(IO\_ADDRESS\(CONTROL\_PADCONF\_ETK\_D2\)\);
David,
Can you point me to the include files where IO_ADDRESS is defined,
and some docs on __raw_readl and similar routines? I've been looking
all over, and am not up to speed yet on how to find things yet.
Jon
[mailto:beagleboard@googlegroups.com] On Behalf Of jmelson
Sent: Saturday, August 29, 2009 8:23 PM
To: Beagle Board
Subject: [beagleboard] Re: gpio interrupt of omap beagle board
David,
If you are getting the kernel source using GIT, then you can find anything
you want by doing
git grep IO_ADDRESS
Dear,
Thanks for your message.
I'm tried the PAD Control and success.
