GPIO problems on ubuntu 16.04
I have a beaglebone black, and I am having some serious problems with the GPIO configuration, trying to migrate our working ubuntu 14.04 installation to ubuntu 16.04. The beaglebone sits on a specifically constructed board, that needs some GPIOs and the CAN-bus working, to function properly. As a starting point, I took the preconfigured 16.04 image from http://elinux.org/BeagleBoardUbuntu#Ubuntu_.2816.04.29 and installed the modified 4.4 kernel (–bone-kernel --lts-4_4 as described here: http://elinux.org/Beagleboard:BeagleBoneBlack_Debian#Mainline_.284.4.x_lts.29).
I modified a dts script for a CAN overlay and got it working. Then, using Adafruit with python3, I got the required GPIOs configured. However autostart of CAN and GPIOs works only, if I force the respective init.d script to start after $network, which could pose a problem later, as the power supply for our wlan rounter is powered on using GPIOs.
Nonetheless, the resulting entries in /sys/class/gpio are:
gpio115, gpio26, gpio38, gpio44, gpio46, gpio48, gpio63, gpio65
With the respective device trees in:
/sys/devices/platform/ocp/44e07000.gpio/gpio/
gpio26 (LED)
/sys/devices/platform/ocp/481ac000.gpio/gpio/
gpio65 (LED)
/sys/devices/platform/ocp/4804c000.gpio/gpio (wird in der BBB_Setup.py benutzt)
gpio38 (scanner_running)
gpio44 (LED)
gpio46 (LED)
gpio48 (scanner_pwr)
gpio63 (LED)
/sys/devices/platform/ocp/481ae000.gpio/gpio/
gpio115 (motor_pwr)
At this point, I am able to power up the motor with gpio115 and four of the LEDs (gpio44, gpio46, gpio26, gpio65) via python or writing to the value files in the device tree.
Unfortunately gpio48 always stays at measured 0.9V, regardless of the values written to the value file or the output commands issued using python and gpio63 always outputs something similar to a HIGH signal. As I suspected some other conflicting capes, I copied the system from eMMC to uSD and disabled the eMMC and HDMI/HDMI-audio capes in /boot/uEnv.txt. The slots in /sys/bus/platform/devices/bone_capemgr/slots now show only the CAN and the Adafruit capes. pinmux-pins and pingroups in /sys/kernel/debug/pinctrl/44e10800.pinmux look, as if all required pins are configured as GPIO unclaimed. However gpio48 and gpio63 still do not react to any output commands. Then I tried to build a device tree overlay using the patched version of the dtc compiler and configuring the required pins to work as outputs in mode7. Loading this cape gives me a probably kernel related error(see cape-error.log) that does not occur, if w1-gpio and w1-term are loaded using modprobe in advance. Regardless of this cape being loaded, gpio48 and gpio63 are still not working.
I made some logs, that may be helpful with the diagnosis of the problem:
www.defi1.de/beaglebone/cape-slots.log (slots right after booting)
www.defi1.de/beaglebone/dmesg.log (kernel message log right after booting)
www.defi1.de/beaglebone/cape-error.log (error in kernel message log when trying to load my custom cape)
www.defi1.de/beaglebone/overlays.log (the device tree overlays created with Adafruit)
www.defi1.de/beaglebone/pinmux-pins.log
www.defi1.de/beaglebone/piongroups.log
Any help on this would be appreciated.
Denis,
Which kernel version are you using for your system ? Ah ok, you said it at the beginning. a 4.4.xbone variant. Can you easily configure a test system to test the pin with the universal-io config-pin tool ? How I personally did this was . . .
/boot/uEnv.txt
##BeagleBone Black: HDMI (Audio/Video) disabled:
dtb=am335x-boneblack-emmc-overlay.dtb
##Example v4.1.x
#cape_disable=bone_capemgr.disable_partno=
cape_enable=bone_capemgr.enable_partno=univ-all
Then download the config-pin tool.
$ wget https://raw.githubusercontent.com/cdsteinkuehler/beaglebone-universal-io/master/config-pin
$ chmod +x config-pin
check the pin configuration:
$ sudo ./ config-pin -q P9.15 /* gpio48 */
P9_15 Mode: default Direction: in Value: 1
Test gpio48:
$ sudo ./config-pin P9.15 hi
$ sudo ./config-pin -q P9.15
P9_15 Mode: gpio Direction: out Value: 1
$ sudo ./config-pin P9.15 low
P9_15 Mode: gpio Direction: out Value: 0
So if this works. You’ll have some sort of software issue. If it does not . . . you may have defective hardware.
Hello William,
thank you very much for your answer. I just experimented with your solution. Loading the univ-all cape and the setting P9_15 for gpio48 to hi and P8_20 for gpio63 to high I was able to activate and deactivate both pins. If I now just load the univ-all cape at startup both GPIOs seem to behave as required and are powered on by my normal startup code. Unfortunately the kernel log now shows a lot of errors after startup.
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.14-bone11 (root@a4-imx6q-wandboard-2gb) (gcc version 5.3.1 20160413 (Ubuntu/Linaro 5.3.1-14ubuntu2.1) ) #1 Sun Jul 3 07:00:48 UTC 2016
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=50c5387d
[ 0.000000] Machine model: TI AM335x BeagleBone Black
[ 0.000000] cma: Reserved 24 MiB at 0x9e800000
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] On node 0 totalpages: 131072
[ 0.000000] free_area_init_node: node 0, pgdat c0b62d5c, node_mem_map de36d000
[ 0.000000] Normal zone: 1152 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 131072 pages, LIFO batch:31
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] AM335X ES2.1 (sgx neon )
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 129920
[ 0.000000] Kernel command line: console=ttyO0,115200n8 bone_capemgr.enable_partno=univ-all root=UUID=f71c90d7-7127-4727-9b6c-ec6d687c6682 ro rootfstype=ext4 rootwait coherent_pool=1M quiet
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 477068K/524288K available (6817K kernel code, 865K rwdata, 3604K rodata, 456K init, 858K bss, 22644K reserved, 24576K cma-reserved, 0K highmem)
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xe0800000 - 0xff800000 ( 496 MB)
lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf800000 - 0xbfe00000 ( 6 MB)
.text : 0xc0008000 - 0xc0a35940 (10423 kB)
.init : 0xc0a36000 - 0xc0aa8000 ( 456 kB)
.data : 0xc0aa8000 - 0xc0b80558 ( 866 kB)
.bss : 0xc0b83000 - 0xc0c599e4 ( 859 kB)
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[ 0.000010] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000027] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000037] OMAP clocksource: timer1 at 24000000 Hz
[ 0.000278] Console: colour dummy device 80x30
[ 0.000302] WARNING: Your ‘console=ttyO0’ has been replaced by ‘ttyS0’
[ 0.000308] This ensures that you still see kernel messages. Please
[ 0.000313] update your kernel commandline.
[ 0.000330] Calibrating delay loop… 996.14 BogoMIPS (lpj=4980736)
[ 0.089182] pid_max: default: 32768 minimum: 301
[ 0.089297] Security Framework initialized
[ 0.089308] Yama: becoming mindful.
[ 0.089339] AppArmor: AppArmor disabled by boot time parameter
[ 0.089488] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.089498] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.090163] Initializing cgroup subsys io
[ 0.090190] Initializing cgroup subsys memory
[ 0.090225] Initializing cgroup subsys devices
[ 0.090240] Initializing cgroup subsys freezer
[ 0.090258] Initializing cgroup subsys net_cls
[ 0.090271] Initializing cgroup subsys perf_event
[ 0.090283] Initializing cgroup subsys net_prio
[ 0.090296] Initializing cgroup subsys pids
[ 0.090338] CPU: Testing write buffer coherency: ok
[ 0.090383] ftrace: allocating 32685 entries in 64 pages
[ 0.171105] Setting up static identity map for 0x800081c0 - 0x8000820c
[ 0.174927] devtmpfs: initialized
[ 0.187986] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.195805] omap_hwmod: tptc0 using broken dt data from edma
[ 0.195901] omap_hwmod: tptc1 using broken dt data from edma
[ 0.195983] omap_hwmod: tptc2 using broken dt data from edma
[ 0.200226] omap_hwmod: debugss: _wait_target_disable failed
[ 0.254637] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.256654] xor: measuring software checksum speed
[ 0.349152] arm4regs : 1221.600 MB/sec
[ 0.449150] 8regs : 1094.000 MB/sec
[ 0.549151] 32regs : 1132.400 MB/sec
[ 0.649149] neon : 1741.200 MB/sec
[ 0.649156] xor: using function: neon (1741.200 MB/sec)
[ 0.649215] pinctrl core: initialized pinctrl subsystem
[ 0.650857] NET: Registered protocol family 16
[ 0.653829] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.657983] OMAP GPIO hardware version 0.1
[ 0.658389] GPIO line 52 (EMMC ResetN) hogged as output/high
[ 0.665688] No ATAGs?
[ 0.665713] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.839247] raid6: int32x1 gen() 270 MB/s
[ 1.009266] raid6: int32x1 xor() 231 MB/s
[ 1.179278] raid6: int32x2 gen() 391 MB/s
[ 1.349184] raid6: int32x2 xor() 262 MB/s
[ 1.519250] raid6: int32x4 gen() 428 MB/s
[ 1.689176] raid6: int32x4 xor() 286 MB/s
[ 1.859208] raid6: int32x8 gen() 366 MB/s
[ 2.029234] raid6: int32x8 xor() 242 MB/s
[ 2.199169] raid6: neonx1 gen() 1471 MB/s
[ 2.369180] raid6: neonx1 xor() 849 MB/s
[ 2.539175] raid6: neonx2 gen() 1789 MB/s
[ 2.709174] raid6: neonx2 xor() 1140 MB/s
[ 2.879147] raid6: neonx4 gen() 1211 MB/s
[ 3.049162] raid6: neonx4 xor() 995 MB/s
[ 3.219174] raid6: neonx8 gen() 927 MB/s
[ 3.389180] raid6: neonx8 xor() 807 MB/s
[ 3.389185] raid6: using algorithm neonx2 gen() 1789 MB/s
[ 3.389191] raid6: … xor() 1140 MB/s, rmw enabled
[ 3.389197] raid6: using intx1 recovery algorithm
[ 3.390557] edma 49000000.edma: Legacy memcpy is enabled, things might not work
[ 3.396116] edma 49000000.edma: TI EDMA DMA engine driver
[ 3.399984] SCSI subsystem initialized
[ 3.400256] libata version 3.00 loaded.
[ 3.400518] usbcore: registered new interface driver usbfs
[ 3.400586] usbcore: registered new interface driver hub
[ 3.400650] usbcore: registered new device driver usb
[ 3.401067] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c0_pins, deferring probe
[ 3.401103] omap_i2c 4819c000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c2_pins, deferring probe
[ 3.401190] media: Linux media interface: v0.10
[ 3.401239] Linux video capture interface: v2.00
[ 3.401320] pps_core: LinuxPPS API ver. 1 registered
[ 3.401357] PTP clock support registered
[ 3.401851] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[ 3.402813] NetLabel: Initializing
[ 3.402823] NetLabel: domain hash size = 128
[ 3.402828] NetLabel: protocols = UNLABELED CIPSOv4
[ 3.402878] NetLabel: unlabeled traffic allowed by default
[ 3.403417] clocksource: Switched to clocksource timer1
[ 3.481712] NET: Registered protocol family 2
[ 3.482393] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 3.482436] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[ 3.482474] TCP: Hash tables configured (established 4096 bind 4096)
[ 3.482539] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 3.482555] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 3.482718] NET: Registered protocol family 1
[ 3.483134] RPC: Registered named UNIX socket transport module.
[ 3.483146] RPC: Registered udp transport module.
[ 3.483151] RPC: Registered tcp transport module.
[ 3.483156] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 3.483660] Unpacking initramfs…
[ 3.800971] Freeing initrd memory: 4676K (cfb6f000 - d0000000)
[ 3.801408] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[ 3.803282] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 3.803390] audit: initializing netlink subsys (disabled)
[ 3.803600] audit: type=2000 audit(3.740:1): initialized
[ 3.804489] zbud: loaded
[ 3.804737] VFS: Disk quotas dquot_6.6.0
[ 3.804788] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 3.805307] NFS: Registering the id_resolver key type
[ 3.805370] Key type id_resolver registered
[ 3.805377] Key type id_legacy registered
[ 3.805401] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 3.805657] fuse init (API version 7.23)
[ 3.805856] SGI XFS with ACLs, security attributes, realtime, no debug enabled
[ 3.810039] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 3.810199] io scheduler noop registered
[ 3.810215] io scheduler deadline registered
[ 3.810258] io scheduler cfq registered (default)
[ 3.811172] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 3.812720] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 3.814986] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 155, base_baud = 3000000) is a 8250
[ 3.815445] console [ttyS0] enabled
[ 3.816447] [drm] Initialized drm 1.1.0 20060810
[ 3.817466] usbcore: registered new interface driver dln2
[ 3.873470] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6
[ 3.873488] davinci_mdio 4a101000.mdio: detected phy mask fffffffe
[ 3.873804] davinci_mdio: dt: updated phy_id[0] from phy_mask[fffffffe]
[ 3.880085] libphy: 4a101000.mdio: probed
[ 3.880116] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
[ 3.880720] cpsw 4a100000.ethernet: Detected MACID = d0:5f:b8:d6:21:53
[ 3.881940] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 3.881986] ehci-platform: EHCI generic platform driver
[ 3.882113] ehci-omap: OMAP-EHCI Host Controller driver
[ 3.882407] usbcore: registered new interface driver usb-storage
[ 3.883666] 47401300.usb-phy supply vcc not found, using dummy regulator
[ 3.885569] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[ 3.885583] musb-hdrc: MHDRC RTL version 2.0
[ 3.885590] musb-hdrc: setup fifo_mode 4
[ 3.885607] musb-hdrc: 28/31 max ep, 16384/16384 memory
[ 3.886432] 47401b00.usb-phy supply vcc not found, using dummy regulator
[ 3.888156] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[ 3.888169] musb-hdrc: MHDRC RTL version 2.0
[ 3.888175] musb-hdrc: setup fifo_mode 4
[ 3.888188] musb-hdrc: 28/31 max ep, 16384/16384 memory
[ 3.888274] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 3.888301] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[ 3.888481] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.888492] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.888500] usb usb1: Product: MUSB HDRC host driver
[ 3.888508] usb usb1: Manufacturer: Linux 4.4.14-bone11 musb-hcd
[ 3.888515] usb usb1: SerialNumber: musb-hdrc.1.auto
[ 3.889148] hub 1-0:1.0: USB hub found
[ 3.889183] hub 1-0:1.0: 1 port detected
[ 3.897250] mousedev: PS/2 mouse device common for all mice
[ 3.898475] omap_rtc 44e3e000.rtc: already running
[ 3.898793] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[ 3.899307] i2c /dev entries driver
[ 3.899585] Driver for 1-wire Dallas network protocol.
[ 3.901259] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 3.901585] sdhci: Secure Digital Host Controller Interface driver
[ 3.901593] sdhci: Copyright© Pierre Ossman
[ 3.901951] omap_hsmmc 48060000.mmc: Got CD GPIO
[ 3.933848] Synopsys Designware Multimedia Card Interface Driver
[ 3.934117] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.934165] ledtrig-cpu: registered to indicate activity on CPUs
[ 3.934248] hidraw: raw HID events driver © Jiri Kosina
[ 3.935841] usbcore: registered new interface driver usbhid
[ 3.935849] usbhid: USB HID core driver
[ 3.938079] ashmem: initialized
[ 3.938588] remoteproc0: wkup_m3 is available
[ 3.938600] remoteproc0: Note: remoteproc is still under development and considered experimental.
[ 3.938607] remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn’t yet guaranteed.
[ 3.939993] oprofile: using arm/armv7
[ 3.940494] NET: Registered protocol family 10
[ 3.941602] mip6: Mobile IPv6
[ 3.941627] NET: Registered protocol family 17
[ 3.941733] Key type dns_resolver registered
[ 3.941748] mpls_gso: MPLS GSO support
[ 3.943051] omap_voltage_late_init: Voltage driver support not added
[ 3.952027] ThumbEE CPU extension supported.
[ 3.952052] Registering SWP/SWPB emulation handler
[ 3.952788] registered taskstats version 1
[ 3.952927] zswap: loaded using pool lzo/zbud
[ 3.953807] Btrfs loaded
[ 3.971153] mmc0: host does not support reading read-only switch, assuming write-enable
[ 3.973268] mmc0: new high speed SDHC card at address 0007
[ 3.974375] Key type encrypted registered
[ 3.974650] mmcblk0: mmc0:0007 SD16G 14.6 GiB
[ 3.976714] input: tps65217_pwr_but as /devices/platform/ocp/44e0b000.i2c/i2c-0/0-0024/input/input0
[ 3.976911] mmcblk0: p1
[ 4.000056] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[ 4.000505] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 4.000541] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 4.001788] at24 2-0054: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 4.002100] at24 2-0055: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 4.002402] at24 2-0056: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 4.002696] at24 2-0057: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 4.002725] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 100 kHz
[ 4.009122] bone_capemgr bone_capemgr: Baseboard: ‘A335BNLT,00C0,3214BBBK6582’
[ 4.009146] bone_capemgr bone_capemgr: compatible-baseboard=ti,beaglebone-black - #slots=4
[ 4.063438] bone_capemgr bone_capemgr: slot #0: No cape found
[ 4.123429] bone_capemgr bone_capemgr: slot #1: No cape found
[ 4.183424] bone_capemgr bone_capemgr: slot #2: No cape found
[ 4.243426] bone_capemgr bone_capemgr: slot #3: No cape found
[ 4.249214] bone_capemgr bone_capemgr: enabled_partno PARTNO ‘univ-all’ VER ‘N/A’ PR ‘0’
[ 4.249227] bone_capemgr bone_capemgr: slot #4: override
[ 4.249239] bone_capemgr bone_capemgr: Using override eeprom data at slot 4
[ 4.249253] bone_capemgr bone_capemgr: slot #4: ‘Override Board Name,00A0,Override Manuf,univ-all’
[ 4.249498] bone_capemgr bone_capemgr: initialized OK.
[ 4.250702] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01 00:21:33 UTC (946686093)
[ 4.250729] of_cfs_init
[ 4.250812] of_cfs_init: OK
[ 4.269842] PM: Hibernation image not present or could not be loaded.
[ 4.270708] Freeing unused kernel memory: 456K (c0a36000 - c0aa8000)
[ 4.402977] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.413598] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.414326] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.415037] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.415258] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.415430] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.416039] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.416236] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.416401] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.416992] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.417183] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.417348] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.417946] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.418140] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.418302] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.418909] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.419096] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.419257] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.419891] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.420088] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.420255] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.420907] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.421110] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.421273] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.421910] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.422106] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.422267] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.422925] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.423119] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.423283] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.424090] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.424306] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.424476] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.431206] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.431553] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.431743] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.432574] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.432804] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.432976] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.442452] random: udevadm urandom read with 9 bits of entropy available
[ 4.444134] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.445216] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.445466] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.445648] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.445832] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.446724] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.446947] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.447116] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.447299] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.448159] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.448372] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.448539] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.448717] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.454589] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.454913] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.455101] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.455300] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.456199] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.456434] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.456607] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.456792] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.464683] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.465028] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.465223] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.465420] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.466358] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.466595] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.466768] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.466952] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.467807] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.468031] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.468202] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.468383] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.469359] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.469580] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.469751] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.469933] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.470930] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.471153] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.471322] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.471501] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.472506] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.472726] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.472900] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.473078] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.474223] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.474465] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.474641] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.474835] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.475844] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.476065] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.476236] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.476425] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.484771] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.485105] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.485297] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.485501] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.489709] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.490040] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.490230] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.490429] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.491584] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.491828] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.492011] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.492210] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.494670] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.494968] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.495152] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.495349] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.496521] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.496763] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.496936] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.497124] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.500573] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.500891] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.501081] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.501289] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.504935] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.505273] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.505467] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.505662] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.515111] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.515449] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.515644] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.515843] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.521645] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.521985] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.522184] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.522382] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.523900] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.524163] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.524343] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.524535] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.525916] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.526166] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.526341] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.526538] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.529906] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.530221] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.530414] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.530613] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.533868] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.534186] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.534371] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.534569] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.548036] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.548385] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.548585] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.548799] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.550463] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.550725] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.550909] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.551099] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.555362] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.555686] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.555878] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.556081] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.557432] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.557697] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.557879] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.558068] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.562034] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.562357] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.562550] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.562745] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.564349] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.564623] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.564808] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.565000] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.576207] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.576561] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.576763] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.576962] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.578515] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.578781] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.578964] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.579170] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.584077] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.584417] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.584614] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.584816] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.588214] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.588542] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.588735] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.588931] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.597163] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.597509] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.597704] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.597900] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.599939] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.600213] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.600402] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.600602] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.615509] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.615865] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.616063] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.616261] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.620921] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.621258] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.621455] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.621653] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.626180] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.626513] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.626710] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.626923] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.630895] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.631224] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.631419] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.631618] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.636571] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.636905] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.637104] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.637305] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.666218] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.666571] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.666769] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.666969] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.669349] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.669641] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.669825] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.670020] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.675627] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.675968] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.676164] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.676363] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.682133] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.682478] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.682681] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.682893] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.695991] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.696341] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.696541] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.696745] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.699136] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.699416] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.699605] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.699805] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.705942] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.706289] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.706487] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.706692] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.712665] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.713015] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.713216] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.713492] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.726596] gpio-of-helper ocp:cape-universal: Allocated GPIO id=0
[ 4.726743] gpio-of-helper ocp:cape-universal: Allocated GPIO id=1
[ 4.726883] gpio-of-helper ocp:cape-universal: Allocated GPIO id=2
[ 4.726999] gpio-of-helper ocp:cape-universal: Allocated GPIO id=3
[ 4.727120] gpio-of-helper ocp:cape-universal: Allocated GPIO id=4
[ 4.727236] gpio-of-helper ocp:cape-universal: Allocated GPIO id=5
[ 4.727349] gpio-of-helper ocp:cape-universal: Allocated GPIO id=6
[ 4.727468] gpio-of-helper ocp:cape-universal: Allocated GPIO id=7
[ 4.727585] gpio-of-helper ocp:cape-universal: Allocated GPIO id=8
[ 4.727705] gpio-of-helper ocp:cape-universal: Allocated GPIO id=9
[ 4.727819] gpio-of-helper ocp:cape-universal: Allocated GPIO id=10
[ 4.727941] gpio-of-helper ocp:cape-universal: Allocated GPIO id=11
[ 4.728068] gpio-of-helper ocp:cape-universal: Allocated GPIO id=12
[ 4.728186] gpio-of-helper ocp:cape-universal: Allocated GPIO id=13
[ 4.728301] gpio-of-helper ocp:cape-universal: Allocated GPIO id=14
[ 4.728421] gpio-of-helper ocp:cape-universal: Allocated GPIO id=15
[ 4.728541] gpio-of-helper ocp:cape-universal: Allocated GPIO id=16
[ 4.728663] gpio-of-helper ocp:cape-universal: Allocated GPIO id=17
[ 4.728781] gpio-of-helper ocp:cape-universal: Allocated GPIO id=18
[ 4.728897] gpio-of-helper ocp:cape-universal: Allocated GPIO id=19
[ 4.729026] gpio-of-helper ocp:cape-universal: Allocated GPIO id=20
[ 4.729152] gpio-of-helper ocp:cape-universal: Allocated GPIO id=21
[ 4.729271] gpio-of-helper ocp:cape-universal: Allocated GPIO id=22
[ 4.729433] gpio-of-helper ocp:cape-universal: Allocated GPIO id=23
[ 4.729558] gpio-of-helper ocp:cape-universal: Allocated GPIO id=24
[ 4.729682] gpio-of-helper ocp:cape-universal: Allocated GPIO id=25
[ 4.729803] gpio-of-helper ocp:cape-universal: Allocated GPIO id=26
[ 4.729924] gpio-of-helper ocp:cape-universal: Allocated GPIO id=27
[ 4.730051] gpio-of-helper ocp:cape-universal: Allocated GPIO id=28
[ 4.730171] gpio-of-helper ocp:cape-universal: Allocated GPIO id=29
[ 4.730279] gpio-of-helper ocp:cape-universal: Allocated GPIO id=30
[ 4.730395] gpio-of-helper ocp:cape-universal: Allocated GPIO id=31
[ 4.730506] gpio-of-helper ocp:cape-universal: Allocated GPIO id=32
[ 4.730619] gpio-of-helper ocp:cape-universal: Allocated GPIO id=33
[ 4.730730] gpio-of-helper ocp:cape-universal: Allocated GPIO id=34
[ 4.730839] gpio-of-helper ocp:cape-universal: Allocated GPIO id=35
[ 4.730955] gpio-of-helper ocp:cape-universal: Allocated GPIO id=36
[ 4.731066] gpio-of-helper ocp:cape-universal: Allocated GPIO id=37
[ 4.731180] gpio-of-helper ocp:cape-universal: Allocated GPIO id=38
[ 4.731290] gpio-of-helper ocp:cape-universal: Allocated GPIO id=39
[ 4.731402] gpio-of-helper ocp:cape-universal: Allocated GPIO id=40
[ 4.731520] gpio-of-helper ocp:cape-universal: Allocated GPIO id=41
[ 4.731629] gpio-of-helper ocp:cape-universal: Allocated GPIO id=42
[ 4.731743] gpio-of-helper ocp:cape-universal: Allocated GPIO id=43
[ 4.731876] gpio-of-helper ocp:cape-universal: Allocated GPIO id=44
[ 4.731991] gpio-of-helper ocp:cape-universal: Allocated GPIO id=45
[ 4.732111] gpio-of-helper ocp:cape-universal: Allocated GPIO id=46
[ 4.732224] gpio-of-helper ocp:cape-universal: Allocated GPIO id=47
[ 4.732340] gpio-of-helper ocp:cape-universal: Allocated GPIO id=48
[ 4.732457] gpio-of-helper ocp:cape-universal: Allocated GPIO id=49
[ 4.732573] gpio-of-helper ocp:cape-universal: Allocated GPIO id=50
[ 4.732694] gpio-of-helper ocp:cape-universal: Allocated GPIO id=51
[ 4.732815] gpio-of-helper ocp:cape-universal: Allocated GPIO id=52
[ 4.732928] gpio-of-helper ocp:cape-universal: Allocated GPIO id=53
[ 4.733050] gpio-of-helper ocp:cape-universal: Allocated GPIO id=54
[ 4.733165] gpio-of-helper ocp:cape-universal: Allocated GPIO id=55
[ 4.733283] gpio-of-helper ocp:cape-universal: Allocated GPIO id=56
[ 4.733403] gpio-of-helper ocp:cape-universal: Allocated GPIO id=57
[ 4.743721] gpio-of-helper ocp:cape-universal: Allocated GPIO id=58
[ 4.743880] gpio-of-helper ocp:cape-universal: Allocated GPIO id=59
[ 4.744000] gpio-of-helper ocp:cape-universal: Allocated GPIO id=60
[ 4.744124] gpio-of-helper ocp:cape-universal: Allocated GPIO id=61
[ 4.744243] gpio-of-helper ocp:cape-universal: Allocated GPIO id=62
[ 4.744365] gpio-of-helper ocp:cape-universal: Allocated GPIO id=63
[ 4.744481] gpio-of-helper ocp:cape-universal: Allocated GPIO id=64
[ 4.744603] gpio-of-helper ocp:cape-universal: Allocated GPIO id=65
[ 4.744721] gpio-of-helper ocp:cape-universal: Allocated GPIO id=66
[ 4.744730] gpio-of-helper ocp:cape-universal: ready
[ 4.745070] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.745426] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.745629] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.745840] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.756669] 48022000.serial: ttyS1 at MMIO 0x48022000 (irq = 186, base_baud = 3000000) is a 8250
[ 4.757337] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.757692] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.757888] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.758101] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.759482] 48024000.serial: ttyS2 at MMIO 0x48024000 (irq = 187, base_baud = 3000000) is a 8250
[ 4.759984] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.760282] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.760472] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.760676] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.761919] 481a8000.serial: ttyS4 at MMIO 0x481a8000 (irq = 188, base_baud = 3000000) is a 8250
[ 4.762418] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.762704] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.762894] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.763098] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.775932] 481aa000.serial: ttyS5 at MMIO 0x481aa000 (irq = 189, base_baud = 3000000) is a 8250
[ 4.776595] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.776948] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.777159] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.777372] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.779857] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.780070] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.780247] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.780445] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.784974] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.785200] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.785378] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.785591] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.790884] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.791105] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.791285] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.791487] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.804089] omap_i2c 4802a000.i2c: bus 1 rev0.11 at 100 kHz
[ 4.804433] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 4.804784] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 4.804985] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 4.805193] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 4.807348] bone_capemgr bone_capemgr: slot #4: dtbo ‘univ-all-00A0.dtbo’ loaded; overlay id #0
[ 5.891494] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 6.248304] systemd[1]: System time before build time, advancing clock.
[ 6.355015] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[ 6.355535] systemd[1]: Detected architecture arm.
[ 6.357033] systemd[1]: Set hostname to .
[ 6.801169] systemd[1]: Reached target Encrypted Volumes.
[ 6.801718] systemd[1]: Reached target Swap.
[ 6.802016] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 6.802278] systemd[1]: Listening on udev Kernel Socket.
[ 6.803979] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 6.804308] systemd[1]: Listening on Syslog Socket.
[ 6.804539] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 6.804759] systemd[1]: Listening on Journal Socket (/dev/log).
[ 6.805025] systemd[1]: Listening on Journal Socket.
[ 6.805315] systemd[1]: Listening on udev Control Socket.
[ 6.805962] systemd[1]: Created slice System Slice.
[ 6.806587] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 6.809471] systemd[1]: Mounting POSIX Message Queue File System…
[ 6.813298] systemd[1]: Starting Create list of required static device nodes for the current kernel…
[ 6.828602] systemd[1]: Mounting /sys/kernel/debug…
[ 6.861540] systemd[1]: Started Read required files in advance.
[ 6.897019] systemd[1]: Starting Load Kernel Modules…
[ 6.897272] systemd[1]: Reached target Remote File Systems (Pre).
[ 6.897478] systemd[1]: Reached target Remote File Systems.
[ 6.908207] systemd[1]: Listening on Journal Audit Socket.
[ 6.908669] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 6.914231] systemd[1]: Created slice system-getty.slice.
[ 6.914819] systemd[1]: Created slice User and Session Slice.
[ 6.914940] systemd[1]: Reached target Slices.
[ 6.915205] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 6.918193] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 6.962722] systemd[1]: Starting Journal Service…
[ 7.025347] EXT4-fs (mmcblk0p1): re-mounted. Opts: errors=remount-ro
[ 7.061093] systemd[1]: Mounted POSIX Message Queue File System.
[ 7.061286] systemd[1]: Mounted /sys/kernel/debug.
[ 7.062942] systemd[1]: Started Create list of required static device nodes for the current kernel.
[ 7.074396] systemd[1]: ureadahead.service: Main process exited, code=exited, status=5/NOTINSTALLED
[ 7.075985] systemd[1]: ureadahead.service: Unit entered failed state.
[ 7.076170] systemd[1]: ureadahead.service: Failed with result ‘exit-code’.
[ 7.077153] systemd[1]: Started Load Kernel Modules.
[ 7.078327] systemd[1]: Started Remount Root and Kernel File Systems.
[ 7.569355] systemd[1]: Starting Load/Save Random Seed…
[ 7.586577] systemd[1]: Starting udev Coldplug all Devices…
[ 7.589856] systemd[1]: Mounting FUSE Control File System…
[ 7.593344] systemd[1]: Starting Apply Kernel Variables…
[ 7.682455] systemd[1]: Mounting Configuration File System…
[ 7.728167] systemd[1]: Starting Create Static Device Nodes in /dev…
[ 7.798657] systemd[1]: Mounted Configuration File System.
[ 7.798938] systemd[1]: Mounted FUSE Control File System.
[ 7.802530] systemd[1]: Started Journal Service.
[ 8.976392] systemd-journald[173]: Received request to flush runtime journal from PID 1
[ 10.789131] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 10.789503] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 10.789706] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 10.789915] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 11.524829] Bluetooth: Core ver 2.21
[ 11.524933] NET: Registered protocol family 31
[ 11.524942] Bluetooth: HCI device and connection manager initialized
[ 11.524964] Bluetooth: HCI socket layer initialized
[ 11.524977] Bluetooth: L2CAP socket layer initialized
[ 11.525008] Bluetooth: SCO socket layer initialized
[ 11.604977] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 11.605362] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 11.605568] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 11.605783] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 11.727691] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 11.728076] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 11.728284] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 11.728503] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 11.869004] net eth0: initializing cpsw version 1.12 (0)
[ 11.871351] net eth0: phy found : id is : 0x7c0f1
[ 11.901014] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 12.154141] CAN device driver interface
[ 12.304040] c_can_platform 481cc000.can: c_can_platform device registered (regs=fa1cc000, irq=196)
[ 12.304704] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 12.305085] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 12.305301] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 12.305525] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 12.320254] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 12.320599] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 12.320806] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 12.321023] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 12.344626] c_can_platform 481d0000.can: c_can_platform device registered (regs=fa1d0000, irq=197)
[ 12.345353] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 12.345736] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 12.345957] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 12.346184] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 12.393500] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 12.393891] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 12.394113] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 12.394345] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 12.394793] eqep 48300180.eqep: ver. 1.0
[ 12.395172] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 12.395435] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 12.395624] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 12.395825] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 12.396561] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 12.396814] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 12.396998] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 12.397201] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 12.422800] eqep 48302180.eqep: ver. 1.0
[ 12.423326] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 12.423847] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 12.424087] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 12.424314] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 12.445403] davinci-mcasp 48038000.mcasp: invalid tdm slots: 0
[ 12.475822] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 12.476238] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 12.476459] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 12.476683] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 12.479978] eqep 48304180.eqep: ver. 1.0
[ 12.480516] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 12.480890] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 12.481106] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 12.481327] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 12.556602] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 12.557002] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 12.557229] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 12.557456] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 12.562655] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 12.563057] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 12.563277] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 12.566694] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 12.724063] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 12.724462] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 12.724678] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 12.724902] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 12.725376] davinci-mcasp 4803c000.mcasp: invalid tdm slots: 0
[ 12.988746] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 12.989153] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 12.989446] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 12.989678] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 12.998156] omap_rng 48310000.rng: OMAP Random Number Generator ver. 20
[ 12.998490] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 12.998868] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 12.999088] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 12.999315] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 13.543782] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 13.543811] omap-sham 53100000.sham: initialization failed.
[ 13.549452] omap-sham: probe of 53100000.sham failed with error -22
[ 13.583878] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 13.673276] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 13.673818] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 13.674066] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 13.674299] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 13.756679] pruss_uio 4a300000.pruss: pins are not configured from the driver
[ 13.850597] net eth0: initializing cpsw version 1.12 (0)
[ 13.852941] net eth0: phy found : id is : 0x7c0f1
[ 13.879672] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 13.975217] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 13.975639] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 13.975875] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 13.976109] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 13.997064] random: nonblocking pool is initialized
[ 14.051630] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 14.052039] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 14.052270] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 14.052517] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 14.094171] using random self ethernet address
[ 14.094195] using random host ethernet address
[ 14.094208] using host ethernet address: D0:5F:B8:D6:21:55
[ 14.094215] using self ethernet address: D0:5F:B8:D6:21:50
[ 14.095077] usb0: HOST MAC d0:5f:b8:d6:21:55
[ 14.095145] usb0: MAC d0:5f:b8:d6:21:50
[ 14.095180] using random self ethernet address
[ 14.095191] using random host ethernet address
[ 14.095280] g_ether gadget: Ethernet Gadget, version: Memorial Day 2008
[ 14.095290] g_ether gadget: g_ether ready
[ 14.442274] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 15.844189] cpsw 4a100000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[ 15.844255] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 15.933983] 8021q: 802.1Q VLAN Support v1.8
[ 15.934044] 8021q: adding VLAN 0 to HW filter on device eth0
[ 17.058099] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 17.058514] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 17.058750] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 17.058986] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 17.063170] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 17.063687] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 17.063944] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 17.064183] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 17.074785] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 17.075202] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 17.075436] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 17.075669] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 17.088961] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 17.089385] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 17.089625] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 17.089864] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 17.753149] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 18.822175] net eth0: initializing cpsw version 1.12 (0)
[ 18.826366] net eth0: phy found : id is : 0x7c0f1
[ 18.847803] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 18.847830] 8021q: adding VLAN 0 to HW filter on device eth0
[ 20.147159] bone_capemgr bone_capemgr: part_number ‘BB-DCAN1’, version ‘N/A’
[ 20.147191] bone_capemgr bone_capemgr: slot #5: override
[ 20.147205] bone_capemgr bone_capemgr: Using override eeprom data at slot 5
[ 20.147220] bone_capemgr bone_capemgr: slot #5: ‘Override Board Name,00A0,Override Manuf,BB-DCAN1’
[ 20.151443] bone_capemgr bone_capemgr: slot #5: dtbo ‘BB-DCAN1-00A0.dtbo’ loaded; overlay id #1
[ 20.284997] can: controller area network core (rev 20120528 abi 9)
[ 20.285107] NET: Registered protocol family 29
[ 20.519465] can: raw protocol (rev 20120528)
[ 20.795980] c_can_platform 481cc000.can can0: setting BTR=1c02 BRPE=0000
[ 20.796164] IPv6: ADDRCONF(NETDEV_CHANGE): can0: link becomes ready
[ 20.824162] cpsw 4a100000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[ 20.832192] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 22.106545] bone_capemgr bone_capemgr: part_number ‘BB-ADC’, version ‘N/A’
[ 22.106573] bone_capemgr bone_capemgr: slot #6: override
[ 22.106587] bone_capemgr bone_capemgr: Using override eeprom data at slot 6
[ 22.106602] bone_capemgr bone_capemgr: slot #6: ‘Override Board Name,00A0,Override Manuf,BB-ADC’
[ 22.135824] bone_capemgr bone_capemgr: slot #6: dtbo ‘BB-ADC-00A0.dtbo’ loaded; overlay id #2
[ 22.167244] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 22.167720] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 22.167961] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 22.168204] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
[ 22.278483] ti_am3359-tscadc 44e0d000.tscadc: chan 0 step_avg truncating to 16
[ 22.278508] ti_am3359-tscadc 44e0d000.tscadc: chan 1 step_avg truncating to 16
[ 22.278517] ti_am3359-tscadc 44e0d000.tscadc: chan 2 step_avg truncating to 16
[ 22.278526] ti_am3359-tscadc 44e0d000.tscadc: chan 3 step_avg truncating to 16
[ 22.278535] ti_am3359-tscadc 44e0d000.tscadc: chan 4 step_avg truncating to 16
[ 22.278544] ti_am3359-tscadc 44e0d000.tscadc: chan 5 step_avg truncating to 16
[ 22.278552] ti_am3359-tscadc 44e0d000.tscadc: chan 6 step_avg truncating to 16
[ 22.289634] bone-pinmux-helper ocp:P8_03_pinmux: could not find pctldev for node /ocp/interrupt-controller@48200000, deferring probe
[ 22.290061] bone-pinmux-helper ocp:P8_04_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_core_ck, deferring probe
[ 22.290302] bone-pinmux-helper ocp:P8_05_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/dpll_disp_ck, deferring probe
[ 22.290537] bone-pinmux-helper ocp:P8_18_pinmux: could not find pctldev for node /ocp/l4_wkup@44c00000/prcm@200000/clocks/pruss_ocp_gclk, deferring probe
I am suspecting the errors to occur, because the kernel tries to locate stuff in directories named using the schme xxx@12345. However on my system, most of the directories are named using the scheme 12345.xxx.
Also checking the configuration of my LED pins gives me an error on one of the pins:
ubuntu@beagle6:~$ sudo ./config-pin -q P9.15 P9_15 Mode: default Direction: out Value: 1 ubuntu@beagle6:~$ sudo ./config-pin -q P8.12 P8_12 Mode: default Direction: out Value: 0 ubuntu@beagle6:~$ sudo ./config-pin -q P8.14 P8_14 Mode: default Direction: out Value: 0 ubuntu@beagle6:~$ sudo ./config-pin -q P8.16 P8_16 Mode: default Direction: out Value: 0 ubuntu@beagle6:~$ sudo ./config-pin -q P8.18 Cannot read pinmux file: /sys/devices/platform/ocp/ocp*P8_18_pinmux/state ubuntu@beagle6:~$ sudo ./config-pin -q P8.20 P8_20 Mode: default Direction: out Value: 0
Is there any way to get rid of the errors and configure the pins using a normal cape? I thought of making a modified copy of am335x-boneblack-emmc-
overlay.dtb by using the dts source from
[https://github.com/RobertCNelson/dtb-rebuilder/tree/4.4-ti/src/arm](https://github.com/RobertCNelson/dtb-rebuilder/tree/4.4-ti/src/arm)
Hi denis,
I do not know what to say. That Linux image you have seems to be incomplete or somehow broken.
Hello William,
that doesn’t sound very encouraging. I just re-downloaded the image from http://elinux.org/BeagleBoardUbuntu#Ubuntu_.2816.04.29 , flashed it on an empty uSD card loaded am335x-boneblack-emmc-
overlay.dtb and univ-all cape to ensure it wasn’t me who broke the image during install. Unfortunately the kernel log showed the same errors. Then I tried to fake the missing directories by creating symlinks to the existing ones, but it didn’t work, because symlinks can not be created in sysfs directories.
Do you happen to know a download location for a working ubuntu 16.04 beaglebone image with a 4.4.x kernel?
No I do not. Ubuntu on the beaglebones is not my thing . . .
Ok, can’t be helped then. :slight_smile: Thank you for spending some time on my problem.
denis,
For what it’s worth. Ubuntu mate does not seem very . . .“complete” on any ARM platform right now. For instance, the Odroid XU4 which has 4 cores A15’s and 4 cores A7 uses an armv7 kernel( 32 bit ). Where the A15 cores are actually 64bit cores I believe. Same for the RaspberryPI 3 , and odroid C2 which both use A53 processors that are also 64bit cores . . . and this is not only for Ubuntu. It for all Linux’s as far as I can tell.
But the point I’m trying to make here is that Ubuntu mate is new, so give it some time, and these issues which may, or may not be kernel related. To settle down. So if you have to use Ubuntu, in your shoes. I’d stick with 14.04. But honestly I’d never use Ubuntu on this specific hardware anyhow . . . an odroid XU4 sure, but not a beaglebone.
I don’t know why William doesn’t take a quick look on the ARM website before making statements like this. CortexA15 is a 32bit processor. CortexA53 is a low power 64bit processor.
John
One more thing, the Linux kernel used on RaspberryPi3, etc are still running in 32bit mode:
https://www.linux.com/news/raspberry-pi-3-still-essentially-32-bit-sbc-now
John
I’m using ubuntu, because it’s the recommended platform for ros. Apart from that, I managed to mostly solve the ubuntu 16.04 issues in the meantime. I noticed, that almost all of my startup error messages were related to pins P8_03, P8_04, P8_05 and P8_18. So I made a modified version of univ-all-00A0.dts with all entries regarding those pins removed. I also took out the can related entries, to not interfere with my separate can dts. After compiling those dts files and loading the modified univ-all cape in uEnv.txt I’m finally able to access all required GPIOs.
The problem of configuring and activating the GPIOs and setting up the can bus automatically at boot time required a different approach. I am using an init.d script to do these things at startup. At first, it did only work, if I added a dependency to the script to start after $network. Otherwise the configuration is done too early in the bootup process and has no effect at all. This however required a working network cable to be plugged in at startup, which is not possible, as the network router on my robot can only be powered on using some GPIO signals. As I was unable to figure out a way, to make $network not dependent of link-up on the lan port, I removed the dependency from the script and added a 10 second sleep call at the beginning of the script(determined the delay by examining the timings in syslog). This way the GPIOs and can bus are automatically set up after the required modules got loaded and powers on my router, without having to wait for link-up. It is not a beautiful solution, but it seems to be reliable.
