I want to use one of the gpio pin from the expansion board of my beagle board xm. From /sys/class/gpio I can set successfully the “high or 1” and “low or 0” of VALUE (from a voltmeter it gives 1.8V for 1 and 0V for 0 form the pin) to a particular gpio given the DIRECTION is “out”, but when I set the DIRECTION to “in” the VALUE change to always “high or 1”. For my application I need to configure the GPIO with “in”=DIRECTION that will give “low/0”=VALUE so that when I apply 1.8V to that pin it will give “1”= Value. Probably, the reason why the GPIO pin gives always “1” during input state because it is currently set as pull-up function, Im wondering if there is a way to set it up to pulldown function.
Jeffrey
