On Tue, 12 Sep 2017 22:54:32 -0700 (PDT), Mala Dies
<functt@gmail.com> declaimed the following:
Hello Again,
Here: Command "python setup.py egg_info" failed with error code 1 in
/tmp/pip-build-euoTR3/math/Dang: This is what printed out when I tried to get "math" set up by pip on
Debian. No good.
"math" is a /standard/ library for Python -- you should not have to
download/install anything for that library.
If it isn't working, make sure you don't have some experimental file of
your own named "math.py" (or "math.pyc", "math.pyd") getting in the way.
