hello sir
I have done " frisky-armv5el " well with qemu and on going to move to
beagle board
next step i plan to do " Grumpy Griffin ARMv6EL-VFP " ,but I meet some
problem
could anybody share his working debootstrap command sample with me
like " frisky-armv5el " , but for " Grumpy Griffin ARMv6EL-VFP "
sudo debootstrap --verbose --arch arm --foreign --exclude=dash frisky
disk/ http://repository.handhelds.org/frisky-armv5el/
any suggestion is welcome
At this time, only frisky is supported with debootstrap scripts.
Reading the Mojo archive, it looks like they are very busy attempting
to get ubuntu 8.04 ported first, before they update the other
distributions.
If you'd like to create one yourself (not easy), navigate to
/usr/lib/debootstrap/scripts and open 'frisky'
However, i do have an updated frisky-armv6el-vfp if your interested.
I should warn you thou, run it on a second sd card, (or backup your
previous), since i'm unable to get the boot correctly on any qemu or
hardware.
--exclude=dash,handhelds-keyring frisky disk/
http://repository.handhelds.org/frisky-armv6el-vfp/
hello robert
thank you for your kindly explanation ,
Aung
