REALLY THANKS so much for helping me in test minicom
but want to ask
first
about iused gtkterm
he printed angstrom
but before loading and all of this
in terminal he printed it
(gtkterm:2307): GLib-GObject-WARNING **: /build/buildd/glib2.0-2.26.0/
gobject/gsignal.c:3081: signal name `depressed' is invalid for
instance `0x8a90088'
second within loading file he print that
not i don't remember for CRC and NAND ???//
but he print angstrom
after this he print angstrom distribution for beagle board ttys2?
Which BeagleBoard are you using? On the -xM this is normal as it has no NAND on board to store this information. That is why we use the boot.scr file. On a Rev C4, this can be the case if you have not stored any of the environment variables. This is not an indication of a problem with the board.
NAND is Flash memory, non-volatile memory.
Environment variables are data that tells the kernel how to operate and the environment under which is is running.
You cat try using google to look up these terms and find a lot of information about them.
