I want to connect to my beaglebone an LCD display which uses a 3-wire
SPI interface: communication in both directions (to and from device)
is implemented using only CS, SCK and a single data wire. The data
wire is used in half-duplex mode, with direction switched depending
whether write or read operation is expected. The SRM says that the SPI
interface in the processor supports this mode, but how can I control
the direction of the data line from user-space program? Since I can't
control pinmuxing, changing pin direction is not possible. Will it be
enough just to flip the bit in OE register?
Thx,
j.
