Hang after ehci-omap.0 supply hsusb1 not found, using dummy regulator on Beagleboard XM
Does anyone know why or what is happening here? After I see this over the serial
“ehci-omap.0 supply hsusb1 not found, using dummy regulator” the terminal just
sits there.
If it helps there is an issue with the angstrom validation image also, looks like it is in a similar area, something is up with usb?
Texas Instruments X-Loader 1.4.4ss (Aug 19 2010 - 02:49:27)
Beagle xM Rev A
Reading boot sector
Loading u-boot.bin from mmc
U-Boot 2010.03-dirty (Aug 20 2010 - 20:50:46)
OMAP3630/3730-GP ES1.0, CPU-OPP2, L3-165MHz,
I2C: ready
DRAM: 512 MB
NAND: 256 MiB
*** Warning - bad CRC or NAND, using default environment
In: serial
Out: serial
Err: serial
Probing for expansion boards, if none are connected you’ll see a harmless I2C error.
No EEPROM on expansion board
Beagle xM Rev A
Die ID #210e00001bf00000015739ea07018016
mmc1 is available
The user button is currently NOT pressed.
reading boot.scr
** Unable to read “boot.scr” from mmc 1:1 **
reading user.scr
755 bytes read
Running bootscript from mmc …
Executing script at 80200000
mmc1 is available
reading ramdisk.gz
19960110 bytes read
reading uImage
3190568 bytes read
Booting from ramdisk …
Booting kernel from Legacy Image at 80200000 …
Image Name: Angstrom/2.6.32/beagleboard
Data Size: 3190504 Bytes = 3 MB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum … OK
Loading Kernel Image … OK
OK
Starting kernel …
Uncompressing Linux…
[ 0.000000] Linux version 2.6.32 (ubuntu@ip-10-204-115-71) (gcc version 4.3.3 (GCC) ) #3 PREEMPT Wed Aug 18 15:53:03 UTC 2010
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] Machine: OMAP3 Beagle Board
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] OMAP3630/DM3730 ES1.0 (l2cache iva sgx neon isp 192mhz_clk )
[ 0.000000] SRAM: Mapped pa 0x40200000 to va 0xfe400000 size: 0x100000
[ 0.000000] Reserving 16777216 bytes SDRAM for VRAM
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 117760
[ 0.000000] Kernel command line: console=tty0 console=ttyS2,115200n8 mem=80M@0x80000000 mem=384M@0x88000000 mpurate=1000 buddy=none camera=lbcm3m1 vram=16M2
[ 0.000000] Beagle expansionboard: none
[ 0.000000] Beagle cameraboard: lbcm3m1
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 80MB 384MB = 464MB total
[ 0.000000] Memory: 316288KB available (5880K code, 671K data, 204K init, 0K highmem)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:402
[ 0.000000] Clocking rate (Crystal/Core/MPU): 26.0/332/600 MHz
[ 0.000000] Reprogramming SDRC clock to 332000000 Hz
[ 0.000000] GPMC revision 5.0
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 4.0) with 96 interrupts
[ 0.000000] Total of 96 interrupts on 1 active controller
[ 0.000000] OMAP GPIO hardware version 2.5
[ 0.000000] OMAP clockevent source: GPTIMER12 at 32768 Hz
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [tty0] enabled
[ 0.000000] Calibrating delay loop… 479.96 BogoMIPS (lpj=1871872)
[ 0.000000] Mount-cache hash table entries: 512
[ 0.000000] CPU: Testing write buffer coherency: ok
[ 0.000000] tmpfs: No value for mount option ‘mode’
[ 0.000000] devtmpfs: initialized
[ 0.000000] regulator: core version 0.5
[ 0.000000] NET: Registered protocol family 16
[ 0.000000] Beagle cameraboard: registering i2c2 bus for lbcm3m1
[ 0.000000] Found NAND on CS0
[ 0.000000] Registering NAND on CS0
[ 0.000000] Unable to get DVI reset GPIO
[ 0.000000] omap_init_mbox: platform not supported
[ 0.000000] Target VDD1 OPP = 4, VDD2 OPP = 2
[ 37.449584] OMAP DMA hardware revision 5.0
[ 37.455932] bio: create slab at 0
[ 37.457214] SCSI subsystem initialized
[ 37.458618] usbcore: registered new interface driver usbfs
[ 37.458770] usbcore: registered new interface driver hub
[ 37.458953] usbcore: registered new device driver usb
[ 37.459350] i2c_omap i2c_omap.1: bus 1 rev4.0 at 2600 kHz
[ 37.462036] twl4030: PIH (irq 7) chaining IRQs 368…375
[ 37.462097] twl4030: power (irq 373) chaining IRQs 376…383
[ 37.462371] twl4030: gpio (irq 368) chaining IRQs 384…401
[ 37.464172] regulator: VUSB1V5: 1500 mV normal standby
[ 37.464416] regulator: VUSB1V8: 1800 mV normal standby
[ 37.464660] regulator: VUSB3V1: 3100 mV normal standby
[ 37.465911] twl4030_usb twl4030_usb: Initialized TWL4030 USB module
[ 37.466308] regulator: VMMC1: 1850 <–> 3150 mV normal standby
[ 37.466583] regulator: VDAC: 1800 mV normal standby
[ 37.466827] regulator: VPLL2: 1800 mV normal standby
[ 37.467102] regulator: VSIM: 1800 <–> 3000 mV normal standby
[ 37.467468] regulator: VAUX3: 1800 mV normal standby
[ 37.467834] regulator: VAUX4: 1800 mV normal standby
[ 37.468048] i2c_omap i2c_omap.2: bus 2 rev4.0 at 400 kHz
[ 37.476165] i2c_omap i2c_omap.3: bus 3 rev4.0 at 100 kHz
[ 37.477386] Switching to clocksource 32k_counter
[ 37.486450] musb_hdrc: version 6.0, musb-dma, otg (peripheral+host), debug=0
[ 37.490081] musb_hdrc: USB OTG mode controller at fa0ab000 using DMA, IRQ 92
[ 37.490112] musb_hdrc musb_hdrc: MUSB HDRC host driver
[ 37.490264] musb_hdrc musb_hdrc: new USB bus registered, assigned bus number 1
[ 37.490447] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 37.490478] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 37.490539] usb usb1: Product: MUSB HDRC host driver
[ 37.490570] usb usb1: Manufacturer: Linux 2.6.32 musb-hcd
[ 37.490600] usb usb1: SerialNumber: musb_hdrc
[ 37.491241] hub 1-0:1.0: USB hub found
[ 37.491302] hub 1-0:1.0: 1 port detected
[ 37.492370] NET: Registered protocol family 2
[ 37.492645] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 37.493194] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 37.493713] TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
[ 37.493927] TCP: Hash tables configured (established 16384 bind 16384)
[ 37.493988] TCP reno registered
[ 37.494018] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 37.494049] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 37.494323] NET: Registered protocol family 1
[ 37.494781] RPC: Registered udp transport module.
[ 37.494812] RPC: Registered tcp transport module.
[ 37.494842] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 37.495147] Trying to unpack rootfs image as initramfs…
[ 37.497894] rootfs image is not initramfs (no cpio magic); looks like an initrd
[ 38.188323] Freeing initrd memory: 131072K
[ 38.189239] omap-iommu omap-iommu.0: isp registered
[ 38.191040] VFS: Disk quotas dquot_6.5.2
[ 38.191192] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 38.192260] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 38.193145] JFFS2 version 2.2. (NAND) (SUMMARY) �© 2001-2006 Red Hat, Inc.
[ 38.193969] msgmni has been set to 874
[ 38.197906] alg: No test for stdrng (krng)
[ 38.198242] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254)
[ 38.198272] io scheduler noop registered
[ 38.198303] io scheduler deadline registered
[ 38.198486] io scheduler cfq registered (default)
[ 38.258880] OMAP DSS rev 2.0
[ 38.258972] OMAP DISPC rev 3.0
[ 38.259033] OMAP VENC rev 2
[ 38.259307] OMAP DSI rev 1.0
[ 38.595825] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 38.613067] serial8250.0: ttyS0 at MMIO 0x4806a000 (irq = 72) is a ST16654
[ 38.629669] serial8250.1: ttyS1 at MMIO 0x4806c000 (irq = 73) is a ST16654
[ 38.646209] serial8250.2: ttyS2 at MMIO 0x49020000 (irq = 74) is a ST16654
[ 39.246185] console [ttyS2] enabled
[ 39.256530] brd: module loaded
[ 39.262969] loop: module loaded
[ 39.267486] omap2-nand driver initializing
[ 39.271881] NAND device: Manufacturer ID: 0x20, Chip ID: 0xba (ST Micro NAND 256MiB 1,8V 16-bit)
[ 39.281250] cmdlinepart partition parsing not available
[ 39.286590] Creating 5 MTD partitions on “omap2-nand”:
[ 39.291809] 0x000000000000-0x000000080000 : “X-Loader”
[ 39.298217] 0x000000080000-0x000000260000 : “U-Boot”
[ 39.304626] 0x000000260000-0x000000280000 : “U-Boot Env”
[ 39.310729] 0x000000280000-0x000000680000 : “Kernel”
[ 39.317840] 0x000000680000-0x000010000000 : “File System”
[ 39.409423] usbcore: registered new interface driver catc
[ 39.414886] catc: v2.8:CATC EL1210A NetMate USB Ethernet driver
[ 39.420989] usbcore: registered new interface driver kaweth
[ 39.426666] pegasus: v0.6.14 (2006/09/27), Pegasus/Pegasus II USB Ethernet driver
[ 39.434326] usbcore: registered new interface driver pegasus
[ 39.440063] rtl8150: v0.6.2 (2004/08/27):rtl8150 based usb-ethernet driver
[ 39.447113] usbcore: registered new interface driver rtl8150
[ 39.452911] usbcore: registered new interface driver asix
[ 39.458465] usbcore: registered new interface driver cdc_ether
[ 39.464447] usbcore: registered new interface driver dm9601
[ 39.470214] usbcore: registered new interface driver smsc95xx
[ 39.476104] usbcore: registered new interface driver gl620a
[ 39.481811] usbcore: registered new interface driver net1080
[ 39.487640] usbcore: registered new interface driver plusb
[ 39.493286] usbcore: registered new interface driver rndis_host
[ 39.499328] usbcore: registered new interface driver cdc_subset
[ 39.505401] usbcore: registered new interface driver zaurus
[ 39.511138] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 39.519256] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 39.526123] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[ 39.526123] ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 2
[ 39.526123] ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
This is from Android ICS made by rowboat:
Welcome to minicom 2.5
OPTIONS: I18n
Compiled on May  2 2011, 10:05:24.
Port /dev/ttyUSB0
Press CTRL-A Z for help on special keys
Texas Instruments X-Loader 1.51 (Jul 11 2011 - 21:11:32)
Unsupported Chip!
Beagle xM Rev A
Starting X-loader on MMC
Reading boot sector
213256 Bytes Read from MMC
Starting OS Bootloader from MMC...
Starting OS Bootloader...
U-Boot 2010.06 (Jul 08 2011 - 04:37:45)
OMAP34xx/35xx-GP ES1.0, CPU-OPP2 L3-165MHz
I2C:   ready
DRAM:  256 MiB
NAND:  HW ECC [Kernel/FS layout] selected
256 MiB
In:    serial
Out:   serial
Err:   serial
Beagle xM Rev A/C
mmc1 is available
reading boot.scr
389 bytes read
Running bootscript from mmc ...
## Executing script at 82000000
mmc1 is available
reading uImage
2747624 bytes read
## Booting kernel from Legacy Image at 82000000 ...
   Image Name:   Linux-2.6.37-g6f21605
   Data Size:    2747560 Bytes = 2.6 MiB
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Linux version 2.6.37-g6f21605 (a0131746@sditapps04) (gcc version 4.4.3 (GCC) ) 2
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Reserving 8388608 bytes SDRAM for VRAM
OMAP3630 ES1.0 (l2cache iva sgx neon isp 192mhz_clk )
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 62976
Kernel command line: console=ttyO2,115200n8 androidboot.console=ttyO2 mem=256M 2
PID hash table entries: 1024 (order: 0, 4096 bytes)
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Memory: 248MB = 248MB total
Memory: 245292k/245292k available, 16852k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    DMA     : 0xffc00000 - 0xffe00000   (   2 MB)
    vmalloc : 0xd0800000 - 0xf8000000   ( 632 MB)
    lowmem  : 0xc0000000 - 0xd0000000   ( 256 MB)
    modules : 0xbf000000 - 0xc0000000   (  16 MB)
      .init : 0xc0008000 - 0xc003b000   ( 204 kB)
      .text : 0xc003b000 - 0xc0531000   (5080 kB)
      .data : 0xc0532000 - 0xc0576c80   ( 276 kB)
NR_IRQS:409
Clocking rate (Crystal/Core/MPU): 26.0/400/600 MHz
Reprogramming SDRC clock to 400000000 Hz
dpll3_m2_clk rate change failed: -22
GPMC revision 5.0
Trying to install interrupt handler for IRQ402
Trying to install interrupt handler for IRQ403
Trying to install interrupt handler for IRQ404
Trying to install interrupt handler for IRQ405
Trying to install interrupt handler for IRQ406
Trying to install interrupt handler for IRQ407
Trying to install interrupt handler for IRQ408
Trying to install type control for IRQ409
Trying to set irq flags for IRQ409
OMAP clockevent source: GPTIMER1 at 32768 Hz
Calibrating delay loop... 597.64 BogoMIPS (lpj=2334720)
pid_max: default: 32768 minimum: 301
Security Framework initialized
regulator: dummy:
omap_mux_init: Add partition: #1: core, flags: 0
OMAP3 Beagle Rev: xM
Found NAND on CS0
hw-breakpoint: debug architecture 0x4 unsupported.
bio: create slab <bio-0> at 0
omap_i2c omap_i2c.1: bus 1 rev4.0 at 2600 kHz
twl4030: PIH (irq 7) chaining IRQs 368..375
twl4030: power (irq 373) chaining IRQs 376..383
twl4030: gpio (irq 368) chaining IRQs 384..401
regulator: VMMC1: 1850 <--> 3150 mV at 3000 mV normal standby
regulator: VDVI: 1800 mV normal standby
regulator: VSIM: 1800 <--> 3000 mV at 1800 mV normal standby
omap_i2c omap_i2c.2: bus 2 rev4.0 at 400 kHz
omap_i2c omap_i2c.3: bus 3 rev4.0 at 100 kHz
Advanced Linux Sound Architecture Driver Version 1.0.23.
musb-hdrc: version 6.0, otg (peripheral+host), debug=0
musb-hdrc musb-hdrc.0: dma type: dma-inventra
musb-hdrc musb-hdrc.0: USB OTG mode controller at fa0ab000 using DMA, IRQ 92
IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP reno registered
NetWinder Floating Point Emulator V0.97 (double precision)
AM37x/DM37x  Linux PSP version 04.02.00.07 (OMAP3BEAGLE)
ashmem: initialized
msgmni has been set to 479
OMAP DSS rev 2.0
OMAP DISPC rev 3.0
OMAP VENC rev 2
OMAP DSI rev 1.0
omap_uart.0: ttyO0 at MMIO 0x4806a000 (irq = 72) is a OMAP UART0
omap_uart.1: ttyO1 at MMIO 0x4806c000 (irq = 73) is a OMAP UART1
omap_uart.2: ttyO2 at MMIO 0x49020000 (irq = 74) is a OMAP UART2
console [ttyO2] enabled
omap_uart.3: ttyO3 at MMIO 0x49042000 (irq = 80) is a OMAP UART3
brd: module loaded
loop: module loaded
mtdoops: mtd device (mtddev=name/number) must be supplied
NAND device: Manufacturer ID: 0x20, Chip ID: 0xba (ST Micro )
Creating 5 MTD partitions on "omap2-nand.0":
0x000000000000-0x000000080000 : "X-Loader"
0x000000080000-0x000000260000 : "U-Boot"
0x000000260000-0x000000280000 : "U-Boot Env"
0x000000280000-0x000000680000 : "Kernel"
0x000000680000-0x000010000000 : "File System"
OneNAND driver initializing
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci-omap.0 supply hsusb0 not found, using dummy regulator
