I was attempting to flash Libreboot/Coreboot onto a ThinkPad T400 motherboard using a BeagleBone Black (Rev C) and a Pomona 5252 test clip. The target chip is a Macronix MX25L6405D (SOP-16). The BBB was powered via its 5V DC barrel jack.
To handle the 3.3V load, I distributed the power pins across the BBB headers as follows:
P9_3 (3.3V) → Pin 2 (VCC)
P9_4 (3.3V) → Pin 1 (HOLD#)
P8_3 (3.3V) → Pin 9 (WP#)
P9_1 (GND) → Pin 10 (GND)
Data lines: P9_17 (CS), P9_18 (MOSI), P9_21 (MISO), P9_22 (SCLK)
Immediately upon attaching the clip to the chip, the BBB lost its USB-network connection. Now, with all wires and the SD card removed, the BBB is stuck in a permanent boot loop.
Host PC (Parrot OS):
dmesgshows constant connect/disconnect cycles. The interface is renamed toenxdeadbeef0000before dropping. -
BBB LEDs: The Power LED is solid ON. User LEDs D2 and D3 stay solid ON and never flash, indicating the boot process hangs almost immediately.
Looping: The device resets every few seconds.
Was using P8_3 and P9_3/4 headers simultaneously for the same VCC/Pull-up rail a mistake that could have damaged the PMIC (TPS65217C)?
Does the solid D2/D3 LED state confirm a hardware-level failure in the power delivery system?
Is the BBB likely “bricked” due to back-current from the T400 motherboard, or is there a known recovery method for this specific state?
