Has anyone tried demonstratating android + bluetooth on beagle board with embinux port?
I am able to pair a bluetooth headset using the bluetooth dongle on
command prompt. When tried streaming a wav file using the alsa_aplay
command to the bluetooth device, i got the following error :
ALSA lib external/alsa-lib/src/pcm/pcm.c:2161:(snd_pcm_open_conf)
Cannot open shared library /system/usr/lib/alsa-lib/
libasound_module_pcm_bluetooth.so
aplay: main:590: audio open error: No such file or directory
When further investigated "libasound_module_pcm_bluetooth.so" (shared
library) is not generated by the android build at all. This file gets
generated from the folder extrenal/bluez/utils/audio folder.
I would like to add this to android build system in external/bluez/
utils/audio/Android.mk.
Please help/teach me in doing so of configuring the android make file
for this shared library since i am newbie to android makefile.
Thanks and regards,
Velu
