This is built with all of the necessary components from TI SDK 4.01.00 to support the kmscube application.
However, I am having difficulties with the GBM library. The only way that I can get the kmscube application running is to copy /usr/lib/libgbm.so.2.0.0 from the pre-build SDK binaries. My build of libgbm create a segmentation fault.
Initializing GBM…
gbm_create_device
failed to load module: /usr/lib/gbm/gbm_dri.so: cannot open shared object file: No such file or directory
failed to load module: /usr/lib/gbm/gbm_gallium_drm.so: cannot open shared object file: No such file or directory
loaded module : gbm_pvr.so
found valid GBM backend : gbm_pvr.so
gbm_surface_create
Segmentation fault
