HDMI Cape Pin Error?
It looks like the default HDMI cape is claiming one more pin than it
actually needs. The mcasp0_axr1 pin (ball D13, or P9 pin 41.1) is being
claimed by the HDMI overlay:
https://github.com/beagleboard/linux/blob/3.8.13-bone68/firmware/capes/cape-boneblack-hdmi-00A0.dts#L88
...but isn't actually connected to the HDMI framer or anything other
than P9 (and the 'old' P9 pin 41, ball D14) according to the schematic.
Is this a goof as I expect, or is there some reason an unused audio data
line actually needs to be claimed by the HDMI overlay?
Looks like it should be:
0x06c (PIN_OUTPUT_PULLDOWN | MUX_MODE7) /* gpmc_a11.GPIO1_27 */
http://git.ti.com/gitweb/?p=ti-linux-kernel/ti-linux-kernel.git;a=blob;f=arch/arm/boot/dts/am335x-boneblack.dts;h=a088b1a42b2ec2c80630175ffe997fcd6141e930;hb=refs/heads/ti-linux-3.14.y#l70
That looks much more reasonable.
Do you want to fix this, or should I send in a patch? :wink:
If you want to just add it to your current: 3.8.13-xenomai-pbx branch
https://github.com/cdsteinkuehler/linux-dev/commits/3.8.13-xenomai-pbx
I'll pull that along with the two other changes this weekend.
I've added a fix to the 3.8.13-xenomai-pbx branch and pushed to github,
so it's ready for you to pull anytime.
Note this branch also has a custom LCD cape for the folks over at
Probotix, which you may or may not want to include. I'm not sure it's
final yet, but I can always just send another patch if it's not. :slight_smile:
