HDMI I2C Master Error
Anyone else have this error? The system cannot detect the proper resolutions to run, so it defaults to safe values.
Image: bbx15-eMMC-flasher-debian-8.1-lxqt-4gb-armhf-2015-09-06-4gb
Monitor: Asus 22" IPS HDMI Monitor (Ubuntu shows device as ‘Ancor Communications Inc 22"’)
Cable: Amazon 6’ “High Speed with Ethernet” HDMI cable
I was going to do a little poking around, but didn’t want to duplicate any effort.
Louis
Hi Louis,
No I2C interface on the eMMC.
Tomi ^^ ?
Can you dump the I2C from the terminal and see what you get?
Here's what i have..
https://gist.github.com/RobertCNelson/5c80301830b96e15b94d
same kernel/rootfs on microSD/eMMC (microSD works), cleaned the
*.dmesg for printk differences..
kernel is based on ti's v4.1.x as of last thursday morning...
I’ve done a little digging in the TRM. On pages 4714-4715 I found a pinmux configuration for i2c2 and HDMI DDC. It would appear that SDA and SCL are swapped for DDC vs i2c2. Maybe we could check the register values (CTRL_CORE_PAD_I2C2_SDA and CTRL_CORE_PAD_I2C2_SCL) on eMMC boot vs SD boot?
That was an issue we had on the first version of the board way back when. It was swapped in the processor.
I haven’t verified the addresses, but here is what a devmem2 read outputs:
debian@BeagleBoard-X15:~$ sudo ./devmem2 0x4A003808 /dev/mem opened. Memory mapped at address 0xb6f83000. Value at address 0x4A003808 (0xb6f83808): 0x50001 debian@BeagleBoard-X15:~$ sudo ./devmem2 0x4A00380C /dev/mem opened. Memory mapped at address 0xb6f68000. Value at address 0x4A00380C (0xb6f6880c): 0x50001
I'll try to reproduce this tomorrow when I get back to office.
Tomi
While talking to Gerald/Jason...
After u-boot loads on the eMMC, shove in a microSD, i2c master works again...
And if I boot from microsd, and remove the card, HDMI i2c breaks.
I think the culprit is ldo1 regulator (VDD_SD). Set that to
regulator-always-on, and HDMI works.
Why this happens is that the tpd12s015 (HDMI level shifter/ESD
protection chip) has LS_OE GPIO input, which needs to be enabled for the
HDMI i2c to work. LS_OE comes from gpio6_28. The pin that provides
gpio6_28 is powered by vddshv8 (Table 4-2. Ball Characteristics in data
manual), and vddshv8 comes from VDD_SD.
So when VDD_SD is off, all pins powered by vddshv8 (no matter what the
muxing is), are disabled.
I remember complaining about this already years back on linux-omap, that
(at least at that time) there was no way to define the regulators needed
for pins.
Nishanth, any idea how to fix this?
Tomi
Uggh.. you are right..
https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/commit/?id=5a0f93c6576a83d8d07c1b569641934294439ac0
gives documentation pointers that mandates that all supplies to AM57xx
must remain always-on.
Could you submit a patch upstream fixing this?
Looking through the dts, this seems to be the only miss I did :frowning:
