Hello!
I don’t know exactly.
The monitor shows “16:9 1080/24p”
That’s all.
There is no signal when I type CTRL +ALT + F2
Thanks.
2013년 6월 26일 수요일 오후 11시 3분 12초 UTC+9, Gerald 님의 말:
Hello!
That’s all.
Thanks.
Interesting. The CTRL-ALT-F1 shows the command line interface and it works fine at apparently 1920x1080@24.
I cannot explain why the desktop, CTRL_ALT_F2, which uses the same resolution does not show up.
Hello!
I checked others(CTRL + ALT + F3, F4, F5)
CTRL + ALT + F1 - shows command line.
CTRL + ALT + F2 - no signal
CTRL + ALT + F3 - shows command line.
CTRL + ALT + F4 - shows command line.
CTRL + ALT + F5 - shows command line.
Thanks.
2013년 6월 26일 수요일 오후 11시 40분 4초 UTC+9, Gerald 님의 말:
I have no answer for you. I have not seen this behavior before.
Hello!
I rewrite the image to BBB.
CTRL+ALT+F2 also shows command line.
Thanks.
2013년 6월 26일 수요일 오후 11시 49분 19초 UTC+9, Gerald 님의 말:
Hello!
Can you tell me about Modeline data(like Modeline “1280x720@60” 73.78 1280 1312 1592 1624 720 736 741 757)
if I added “video=HDMI-A-1:1280x720@60” to uENV.txt when the first Logo boot up?
The first Logo boot up is fine, it means at that time the Modeline data is correct for my monitor(I think).
Yes, that should make the logo bigger and if your display likes it, it a\should look OK.
