Greetings.
I have a directory “Setup” on the Beaglebone Black with all my .cpp files stored in it. Within this directory is a sub directory holding all my header files appropriately labeled “header”
To access these files within the beaglebone blacks directories do I have to use
“/home/UART/Setup/header.BlackADC.h”
or simply use
“/header.blackADC.h”
I cannot figure this out.
#include "header.blackADC.h"
and add search path for the header files to the compiler options, e.g.:
g++ -I/home/UART/Setup [other options] your_source.cpp -o your_binary
Jacek
On Mon, 3 Apr 2017 15:19:22 -0700 (PDT), Bill Dussault
<frankietankie@gmail.com> declaimed the
following:
Greetings.
I have a directory "Setup" on the Beaglebone Black with all my .cpp files
header files appropriately labeled "header"
use
Confusing... Do you mean the header files all start with "header.****",
or do you mean the SUBdirectory is named "header"?
<include> "/home/UART/Setup/header.BlackADC.h"
or simply use
<include> "/header.blackADC.h"
Where are you building in?
If building in setup directory, you would specify
#include "subdirectory/header.BlackADC.h"
if they are in the unnamed subdirectory
#include "header/BlackADC.h"
if the subdirectory is named "header"
If building from some other directory, you'll need enough path
specification to find the correct directory.
