I ran into this last week when configuring an I2C RTC device, and I have not seen this mentioned in the group.
Angstrom for the BBB, at least the most recent version, has a selection of device tree files, both in source and precompiled form. I used them as a basis for my own Beagleboard NTPD device tree. I’ve found an ambiguous address reference that tripped me up.
Consider this segment of a device tree for an I2C RTC device, such as the Dallas DS1307, or the DS3231 (packaged as the Chronodot, which I have). I’ve omitted most of it for clarity:
fragment@1 {
target = <&i2c2>;overlay {
/* shut up DTC warnings */
#address-cells = <1>;
#size-cells = <0>;/* DS1307 RTC module */
rtc@68 {
compatible = “dallas,ds1307”;
reg = <0x68>;
Note the rtc@68 address. This is ambiguous. The real address of this device is 0x68 in hex. The DTC parser must interpret numeric values in a default decimal radix, unless it has a hex digit already in it; another device I have is addressed as 3C, which is represented correctly.
My RTC was not being detected by the kernel. The fix is simple: always insert the 0x prefix for all addresses (represented in most databooks in hex); the corrected reference is rtc@0x68. My Chronodot was since detected by the kernel with no fuss.
I’ve “decompiled” the original binary device tree file (BB-BONE-RTC-00A0.dtbo) and it matches the source (BB-BONE-RTC-00A0.dts) as far as the address reference is concerned.
I believe this would affect all I2C devices represented in the device tree. I haven’t had the chance to scan the other device tree files. I am running this on a Beaglebone White, but I have both species of Beaglebone (white and black) and they both are running the latest Angstrom so this problem appears to still exist.
I’ve attached a corrected version of the BB-BONE-RTC-00A0.dts file.
Dave M.
BB-BONE-RTC-00A0.dts.txt (2.01 KB)
