Hello, Helps are needed
Hi, guys
nice to join you, I’m quite new in this area, with a omap3530mini board, which is almost a copy of beagleboard with only tiny differences.
I got quite a few questions and want to get started with the evm asap.
what i have here is:
ICETEK omap3530mini board promoted by ti…
tds560pci emulator
ccs3.3
ubuntu linux by VBox in windows xp.
angstrom demo on board.
the OS environment is already set up.
my project is to make a encoder for h26x: encode raw video in SD card and store back in.
the 560emu. is old and with no omap3530mini driver which means I don’t find the exact board info. in CCS Setup. and the board company seems not to provide any softwares in DSP(no board driver for CCS, no gel docs). What I should do to setup the debug env. in CCS for it?
Normally, if your project needs both arm and dsp, with what tools and under which OS do you develop?
Can anybody show me any development steps and tools to be used? anybody has a software dev. demo?
Many thanks.
this might help you figure.
Using default environment
In : serial
Out : serial
Err : serial
Audio Tone on Speakers … complete
Hit any key to stop autoboot : 0
reading uImage
1856664 bytes read
reading rd - ext 2. bin
3394477 bytes read
Booting kernel from Legacy Image at 80300000 …
Image Name : Linux -2.6.22.18- omap 3
Image Type : ARM Linux Kernel Image ( uncompressed )
Data Size : 1856600 Bytes = 1.8 MB
Load Address : 80008000
Entry Point : 80008000
Verifying Checksum … OK
Loading Kernel Image … OK
OK
Starting kernel …
__ | —’| ‘–.| .-’| | |
‘—’---’–’--’–. |-----’’----’’–’ ‘-----’-’-’-’ (garbled)
The Angstrom Distribution beagleboard ttyS 2
Angstrom 2008.1- test -20080503 beagleboard ttyS 2
beagleboard login :
Hi, guys
nice to join you, I'm quite new in this area, with a omap3530mini board,
ICETEK omap3530mini board promoted by ti..
tds560pci emulator
ccs3.3
store back in.
I suggest you look at http://gstreamer.ti.com, the latest Angstrom
demo with GStreamer integrated, and the gst-openmax software using DSP
Bridge mentioned on this mailing list. They are 2 different solutions
(Bridge and Link) and you should pick whatever works easiest for you.
Your local TI support may be more familiar with one or the other.
the 560emu. is old and with no omap3530mini driver which means I don't
You should be able to use the same setup as for the OMAP35x EVM using
the NAND (not OneNAND) config.
Lauterbach is very popular. For both ARM and DSP debug, CCS is
common, but CCS does not debug well under Linux on the ARM.
Please search the mailing list and the http://eLinux.org/BeagleBoard wiki page.
