Hello World program for GSOC 2014.
Project: Debugging tools for LINUX INDUSTRIAL I/O SUBSYSTEM
helloworld.bin (551 KB)
What is this? I know that GSOC is google summer of code, but what is this helloworld.bin file? Why is it posted here? What does it do? Who might want it? How do you install and run this if you wanted to use it?
Many questions, little information.
It's a requirement of the beagleboard.org GSOC, the user just used the
wrong mailing list.
… talking about iio …
Here is something for you to debug on the beagle bone black:
I use a beagle bone black with a 3.13.6 kernel and would like to get the
./generic_buffer test which comes with the kernel to work.
This is what I do:
echo 1 > /sys/bus/iio/devices/iio_sysfs_trigger/add_trigger
ls
iio:device0 iio_sysfs_trigger trigger0
cat /sys/bus/iio/devices/trigger0/name
sysfstrig1
echo 1 > /sys/bus/iio/devices/iio:device0/scan_elements/in_voltage5_en
./generic_buffer.out -n TI-am335x-adc -t sysfstrig1 -l 128
iio device number being used is 0
iio trigger number being used is 0
sysfstrig1
---> Could not open /trigger/current_trigger
Failed to write current_trigger file
Regards,Robert
Project: Debugging tools for LINUX INDUSTRIAL I/O SUBSYSTEM… talking about iio …
I use a beagle bone black with a 3.13.6 kernel and would like to get the ./generic_buffer test which comes with the kernel to work. This is what I do: echo 1 > /sys/bus/iio/devices/iio_sysfs_trigger/add_trigger ls iio:device0 iio_sysfs_trigger trigger0 cat /sys/bus/iio/devices/trigger0/name sysfstrig1 echo 1 > /sys/bus/iio/devices/iio:device0/scan_elements/in_voltage5_en ./generic_buffer.out -n TI-am335x-adc -t sysfstrig1 -l 128 iio device number being used is 0 iio trigger number being used is 0 sysfstrig1 ---> Could not open /trigger/current_trigger Failed to write current_trigger file
You should ask this question on the Linux-IIO mailing list.
John
