Help about device tree
Hello!
I have built a simple cape for mi BBB (Rev A5C) that export some GPIO, an UART and I2C.
This cape have the eeprom, according to SRM.
How I can write DTS file without become crazy?
There is an IDE or so on?
Any help will be appreciated!
Actually , if you take a look about the dts file . you will find , its very simple .
http://lxr.free-electrons.com/source/arch/arm/boot/dts/am335x-bone-common.dtsi
http://lxr.free-electrons.com/source/arch/arm/boot/dts/am335x-evm.dts
This is the only what I can say, follow the sample , and modify to fit your own
how hard could it be
Hello!
Which kernel version are you using? Devicetree uses overlays in V3.8 and there is also a cape manager in this kernel. However, in later kernels, you have to modify the am335x-boneblack.dts file directly to add the I/O definitions. The following docs will help you understand the device tree:
https://github.com/jadonk/validation-scripts/tree/master/test-capemgr
http://free-electrons.com/pub/conferences/2014/elc/petazzoni-device-tree-dummies/petazzoni-device-tree-dummies.pdf
John
