Hello, Good day for all.
I have today an important problem with my BB.
In this video you can see what is happening:
www.youtube.com/watch?v=AooC1tVZ_tA
As you can see, My BB does not put on the USR0 and the USR1 Leds even the PMU led, just the PWR is ON!!
I need to reinstall the OS, come days, I had installed Ubuntu 11.04 and it was working nice with DVI-D, and Hub ethernet, but today I am trying to reinstall from SD memory and nothing happens! I try to boot from NAND and that does not work. The way that i am trying is to boot, is pressing the USER and RESET buttons, 10 seconds later, i release the RESET buton and 10 sec later I release the RESET button too… That’s the way than the manual form.
Please, somebody have experience with that? I need to know what is wrong exactly with my BB. Thank you so much for support this issue.
Saludos/Regards/Grüsse
Try creating an SD card using the factory SW. Follow the instructions to repair the NAND flash and the following link.
http://circuitco.com/support/index.php?title=BeagleBoard#Image_Files
Gerald.
2012/3/3 Sergio David Sánchez Mendoza <sdsanchezm@gmail.com>
Gerald, thank you for your response, but it is not usefull
information.
I fixed this issue in this form:
The original distro of BB is armstrong linux, so it could be usefull
too.
I was thinking my BeagleBoard was chrashed, but it is not true... It
is just a failure due to remove the SD card in a bad form while the OS
is runing (I did it)...
Thank you for read, some questions is wellcomed.
Sorry to hear it was not useful informatioon. Do you suggest that I remove it?
Hello Gerald.
Absolutelly not, I mean, just in my case was not usefull...
My specific case was the recovery of BB, the nand memory did not have
x-load and u-boot I fixed that issue by flashing it that's all...
other man can find usefull what you said and documents there
Thanks for response
This process I pointed you to reflashes the NAND for you. That is what it was supposed to do if the instructions were followed…
