Ive been looking over the directions on how to build custom u-boot
xloader and kernel. Im able to build the u-boot and xloader how ever
when i try to build the kernel it always builds for the host machine.
ive saw some where that i have to set the compiler machine to Arm but
im not sure how to do that using the code sourcery pre-built
toolchain. any help would be apreciated. also if anyone could help
with trying to build a file system for the beagle board that would
also be aprecciated.
As you're already using the codesourcery cross compiler, you just need to use it
while building your kernel.
Example:
export PATH=$PATH:/path/to/your/codesourcery/toolchain/bin
make ARCH=arm CROSS_COMPILE=arm-none-linux-gnueabi- menuconfig
make ARCH=arm CROSS_COMPILE=arm-none-linux-gnueabi- uImage
or
make ARCH=arm CROSS_COMPILE=arm-none-linux-gnueabi- deb-pkg # to generate a deb file
there is a second part of instructions to build your custom Kernel. Just follow my first mail to build the OE environment than comment the line in $OETREE/build/conf/local.conf: #INHERIT += " rm_work "
So in the directory “$OETREE/angstrom-dev/work/beagleboard-angstrom-linux-gnueabi/linux-omap-2.6.29-r46/git” you can find sources with all patches applied. Insert any changes and you can compile the kernel with OE-toolchain. Just copy defconfig from the directory a level upper and:
make ARCH=arm CROSS_COMPILE=$OETREE/angstrom-dev/cross/armv7a/bin/arm-angstrom-linux-gnueabi- menuconfig
make ARCH=arm CROSS_COMPILE=$OETREE/angstrom-dev/cross/armv7a/bin/arm-angstrom-linux-gnueabi- uImage
