Hello everyone, sorry if my question has been already answered - I have been looking around for a while and haven’t found a good answer.
I am interested in adding some hardware to the Beaglebone Green Wireless board, but in order to do that I need to change some of the device tree/pin mux settings. I would like to eventually build a .img file with all of the beaglebone functionality including my additional hardware for easy SD card loading (as the currently provided images are capable of).
I have never built a Linux image myself, and though this page ( https://eewiki.net/display/linuxonarm/BeagleBone+Black ) is helpful, the formatting makes it confusing which commands correspond to which processes.
My understanding is that images can be built using seeed studio’s image-builder branch: https://github.com/beagleboard/image-builder/tree/smaller-iot
I don’t want to use overlays due to some low level interfaces moving (UARTx → LAN, UARTy → CAN, LDC ->UARTz etc)
Long story short: How can I build my own beaglebone green wireless image with a custom device tree?
looking around for a while and haven't found a good answer.
Just follow it in order, top to bottom...
My understanding is that images can be built using seeed studio's
GitHub - beagleboard/image-builder at smaller-iot
I don't want to use overlays due to some low level interfaces moving (UARTx
-> LAN, UARTy -> CAN, LDC ->UARTz etc)
dtb-rebuilder:
edit the bbgw dts and add ^ those..
Robert,
Thanks for the info - I have been following the steps in the BeagleBone+Black wiki page but encountered problems trying to write to my SD card (Setup microSD card step) as a result of my workstation (Ubuntu in a virtualbox vm on windows 8 on a macbookpro, ended up breaking my vm). In the end I want to have a beaglebone .img file to distribute to many systems, so following your steps to achieve that sounds to me like this:
- Build beaglebone image by following https://eewiki.net/display/linuxonarm/BeagleBone+Black
Completing this yields an SD card with a complete Linux image loaded.
- Boot OS from the SD card, install dtb-rebuilder and edit dts files, run dtb-rebuilder and reboot
After this we have the working OS I wish to distribute
- Use a utility to rip the SD card image for distribution
Is this a correct process for retrieving the .img file I want? Is there a better way to build a .img than ripping it from the SD card? I tried to use image-builder but there is no way to edit the dts during the build (that I could figure out)
Thank you so much for your help!
