help flashing BBB debian
I’m trying to post this again. not sure why my previous post is not showing up.
I’ve been trying to flash my BBB for a few days. Tried the 2gb and 4gb debian emmc flasher images from
I formatted using the HP utility and FAT32 (NTFS was the only other option). I used the 5v plug and held down the boot/user button. At first everything looks ok with the wave LED pattern. About 10 minutes into it, user LED 1 is the only one still on (solid).
this is the dump from serial
U-Boot SPL 2015.01-00001-gb2412df (Jan 29 2015 - 15:01:06)
U-Boot 2015.01-00001-gb2412df (Jan 29 2015 - 15:01:06), Build: jenkins-github_Bootloader-Builder-105
Watchdog enabled
I2C: ready
DRAM: 512 MiB
Using default environment
cpsw
switch to partitions #0, OK
mmc0 is current device
Checking for: /uEnv.txt …
933 bytes read in 9 ms (100.6 KiB/s)
Checking if uenvcmd is set …
Running uenvcmd …
718 bytes read in 53 ms (12.7 KiB/s)
5617184 bytes read in 354 ms (15.1 MiB/s)
2287175 bytes read in 174 ms (12.5 MiB/s)
26098 bytes read in 81 ms (314.5 KiB/s)
Kernel image @ 0x82000000 [ 0x000000 - 0x55b620 ]
Using Device Tree in place at 88000000, end 880095f1
Starting kernel …
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Linux version 3.8.13-bone70 (root@a5-imx6q-wandboard-2gb) (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP Fri Jan 23 02:15:42 UTC 2015
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=50c5387d
[ 0.000000] Machine: Generic AM33XX (Flattened Device Tree), model: TI AM335x BeagleBone
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] AM335X ES2.1 (l2cache sgx neon )
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c0d4e000 s14080 r8192 d14592 u36864
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 129792
[ 0.000000] Kernel command line: console=tty0 console=ttyO0,115200n8 root=/dev/mmcblk0p1 rootfstype=ext4 rootwait fixrtc init=/opt/scripts/tools/eMMC/init-eMMC-flasher-v3.sh
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] __ex_table already sorted, skipping sort
[ 0.000000] allocated 1048576 bytes of page_cgroup
[ 0.000000] please try ‘cgroup_disable=memory’ option if you don’t want memory cgroups
[ 0.000000] Memory: 511MB = 511MB total
[ 0.000000] Memory: 505912k/505912k available, 18376k reserved, 0K highmem
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf800000 - 0xbfe00000 ( 6 MB)
[ 0.000000] .text : 0xc0008000 - 0xc07fda30 (8151 kB)
[ 0.000000] .init : 0xc07fe000 - 0xc083b700 ( 246 kB)
[ 0.000000] .data : 0xc083c000 - 0xc08c3980 ( 543 kB)
[ 0.000000] .bss : 0xc08c3980 - 0xc093d140 ( 486 kB)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
[ 0.000000] NR_IRQS:0 nr_irqs:0 0
[ 0.000000] Total of 128 interrupts on 1 active controller
[ 0.000000] OMAP clockevent source: GPTIMER1 at 24000000 Hz
[ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[ 0.000000] OMAP clocksource: GPTIMER2 at 24000000 Hz
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [tty0] enabled
[ 0.000639] Calibrating delay loop… 993.47 BogoMIPS (lpj=969728)
[ 0.029191] pid_max: default: 32768 minimum: 301
[ 0.029338] Security Framework initialized
[ 0.029403] Mount-cache hash table entries: 512
[ 0.035145] Initializing cgroup subsys cpuacct
[ 0.035191] Initializing cgroup subsys memory
[ 0.035238] Initializing cgroup subsys blkio
[ 0.035330] CPU: Testing write buffer coherency: ok
[ 0.035725] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[ 0.035793] Setting up static identity map for 0x804d4d08 - 0x804d4d54
[ 0.036715] Brought up 1 CPUs
[ 0.036745] SMP: Total of 1 processors activated (993.47 BogoMIPS).
[ 0.037547] devtmpfs: initialized
[ 0.045872] omap_hwmod: wd_timer2: _wait_target_disable failed
[ 0.097997] pinctrl core: initialized pinctrl subsystem
[ 0.098151] rstctl core: initialized rstctl subsystem
[ 0.098434] regulator-dummy: no parameters
[ 0.098761] NET: Registered protocol family 16
[ 0.099292] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.104892] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 0.105527] platform 49000000.edma: alias fck already exists
[ 0.105557] platform 49000000.edma: alias fck already exists
[ 0.105578] platform 49000000.edma: alias fck already exists
[ 0.106298] OMAP GPIO hardware version 0.1
[ 0.108826] gpio-rctrl rstctl.4: loaded OK
[ 0.112207] No ATAGs?
[ 0.112233] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.113527] cpsw.0: No hwaddr in dt. Using 78:a5:04:bc:d6:16 from efuse
[ 0.113563] cpsw.1: No hwaddr in dt. Using 78:a5:04:bc:d6:18 from efuse
[ 0.121624] bio: create slab at 0
[ 0.127879] edma-dma-engine edma-dma-engine.0: TI EDMA DMA engine driver
[ 0.128185] vmmcsd_fixed: 3300 mV
[ 0.129790] SCSI subsystem initialized
[ 0.130044] usbcore: registered new interface driver usbfs
[ 0.130113] usbcore: registered new interface driver hub
[ 0.130325] usbcore: registered new device driver usb
[ 0.131595] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 0.132507] input: tps65217_pwr_but as /devices/ocp.3/44e0b000.i2c/i2c-0/0-0024/input/input0
[ 0.134123] DCDC1: at 1500 mV
[ 0.134987] vdd_mpu: 925 <–> 1325 mV at 1325 mV
[ 0.135807] vdd_core: 925 <–> 1150 mV at 1125 mV
[ 0.136663] LDO1: at 1800 mV
[ 0.137461] LDO2: at 3300 mV
[ 0.138952] LDO3: 1800 mV
[ 0.139764] LDO4: at 3300 mV
[ 0.140480] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[ 0.140986] omap_i2c 44e0b000.i2c: unable to select pin group
[ 0.141466] omap_i2c 4819c000.i2c: bus 1 rev0.11 at 100 kHz
[ 0.142911] omap_i2c 4819c000.i2c: unable to select pin group
[ 0.143077] media: Linux media interface: v0.10
[ 0.143147] Linux video capture interface: v2.00
[ 0.143223] pps_core: LinuxPPS API ver. 1 registered
You need to register. Otherwise, your posts are moderated.
