HELP - HELP - HELP
I made the wifi work as follows ...
1. I found the wifi drivers in Ubuntu and just copied the files to angstrom ...
2. I am not able to do the same with the ethernet not know where is the information, files, or the ethernet adapter in ubuntu so I can do the same.
Hi Diego,
What usb Ethernet adapter is this?
Usando o Google Translate:
Por favor, ligue para um adaptador USB Ethernet x86 pc e digite "lsusb".
but I need it to angstrom
Hi Diego,
Please read, (its in Portuguese) :
http://www.celiojunior.com.br/comofazerperguntas.php
(translation of : http://catb.org/~esr/faqs/smart-questions.html)
For us to help you, we need information... dump lsusb/dmesg/serial boot etc..
Hi Robert,
Even I am facing getting my wi-fi usb adapter work with Angstrom.
Its working with my ubuntu9.04 desktop PC, so I tried copying the
driver files from Desktop to BB, but no success.
Some info about my board;
1) Board version : B7
2) Kernel verison : 2.6.28
Note:- I also tried using 2.6.26 , 2.6.27 and 2.6.29 but got the same
result.
When I plug in my USB adapter I get following error messages on
terminal.
Hi Amit,
What brand/model zd1211? I picked up a couple random ones from
newegg, but they turned out to be an other chipset (rtl8187 which i
already had and works, and one that just entered staging in 2.6.30)...
In theory, there is a fix, i just haven't been able to test it yet..
Would you please try:
http://www.rcn-ee.com/deb/kernel/beagle/jaunty/v2.6.29-58cf2f1-oer39.1/
Use this uImage:
http://www.rcn-ee.com/deb/kernel/beagle/jaunty/v2.6.29-58cf2f1-oer39.1/uImage
and install these modules:
http://www.rcn-ee.com/deb/kernel/beagle/jaunty/v2.6.29-58cf2f1-oer39.1/linux-image-2.6.29-oer39.1_1.0jaunty_armel.deb
Regards
Hi Robert,
Thanks for the reply ... I will try the links you posted.
I have USB wi-fi adapter from my essentials
Model No: ME1001-USB
link: http://www.myessentialssupport.com/product/?pid=ME1001-USB#
I am not sure about the chipset. I tried calling customer support
but ... they are not willing
to tell the chipset used.
Amit
Hi Robert,
Can u tell me how to install the module u suggested on BB.
Amit
Hi Amit,
sudo dpkg -i linux-image-*.deb
(hopefully your using an ubuntu root filesystem. not sure Angstrom
will install it..)
Thanks, Amazon had it in stock, so I'll be able to test it
Monday/Tuesday night..
Hi Diego,
thats more than one page!!!!!
I tried the uImage u send me. But it failed to recognize any of the
USB devices connected to my
USB HUB. I think this is the problem with kernel verison 2009. I faced
this problem previously with 2.6.29 kernel verison.
I couldn't install the module as I am working on Angstrom filesystem.
I dont prefer ubuntu because its very very very slow with BB ver7. I
dont know if this is the
problem in general or specific to my board. But I will try to follow
your instructions with ubuntu
thanks,
Amit
It's the only translation i could find...
This is the section i'm hoping he reads:
http://catb.org/~esr/faqs/smart-questions.html#beprecise
Regards
Actually you could use this with Angstrom...
dl file on debian based pc..
dpkg -x linux-image* ./temp
then copy ./temp to your Angstrom sd card... (need /lib/modules/2.6.29.../)
Hi Robert,
I did,
dpkg -x linux-image* ./temp and copied the contents of ./temp on bb
at
/lib/modules/2.6.29-omap1/
i.e. I copied all three folders in ./temp at the above location ( i.e.
boot, lib and usr)
But event this didnot recognized USB devices with 2.6.29 kernel and
hence could
not get wi-fi working.
Just for info ... what this module is supposed to do.
- Amit
Hi Amit,
Just the lib should have been fine..
During bootup, that uImage should be looking for: /lib/modules/2.6.29-oer39.1/
/lib/modules/2.6.29-oer39.1/kernel/drivers/net/wireless/zd1211rw/zd1211rw.ko
I'm guessing it still needs a little more work, so we will see early
next week, when the modules arrives...
Hi Diego,
How To Ask Questions The Smart Way
and it does not hurt to actually read it all :wink:
Hi Robert,
Currently I am working on Ubuntu to try ur instructions and see if I
get any success.
I try to find out the chipset used in my usb dongle ( ME1001-USB) and
I guess its from Realtech
Any suggestion on the drivers required for realtech chipset.
I was just thinking to try with rtl8187 drivers. Can you tell me from
where can I
get those drivers.
Amit
The rtl8187 drivers are actually built into the kernel already...
This is from digitus usb adapter we use to sell at digikey..
[ 545.775503] phy0: hwaddr 00:18:e7:32:a2:68, RTL8187vB (default) V1
+ rtl8225z2
[ 545.775543] usbcore: registered new interface driver rtl8187
0bda:8187 Realtek Semiconductor Corp. RTL8187 Wireless Adapter
Your ME1001-USB should be zd1211rw based:
https://help.ubuntu.com/community/WifiDocs/WirelessCardsSupported
myessentials
ME1001-USB
ID 050d:705c Belkin Components zd1211rw
Hi Robert,
May be thats what I thought.
But when I did lsusb it showed me device type as Belkin components
F5D7050 v4000 wireless Adapter.
I dont know exactly what driver should be used with this. I am
googling to get some info.
Amit
