After, I got the beagleboard boot up, I tried to compile a loadable
kernel module on beagleboard running Angstrom. However, when I tried
to use the gnu make, the command is not found:
root@beagleboard:~/make_381#
make
-sh: make: not found
Therefore, I tried to download the source from gnu.org to install gnu
make on my beagleboard. I followed the instructions that came with the
source code, which requires me to run ./configure as the first step, I
did but I got the following:
root@beagleboard:~/make_381# ./
configure
checking for a BSD-compatible install... config/install-sh -
c
checking whether build environment is sane...
yes
checking for gawk...
no
checking for mawk...
no
checking for nawk...
no
checking for awk...
awk
checking whether make sets $(MAKE)...
no
checking for gcc...
no
checking for cc...
no
checking for cc...
no
checking for cl...
no
configure: error: no acceptable C compiler found in
$PATH
See `config.log' for more details.
It seems to me like some of the required libraries or something are
missing, I tried doing a "opkg install gawk or awk" but none of them
work, anyone knows how to get gnu make working on beagleboard ?
Is any reason you did not do cross-compile in Host PC? You should
probably cross-compile your stuff in host pc and then copy the
binaries to target file system.
I replied from Web; but somehow the reply did not send out. I am trying again...
Is any reason you did not do cross-compile in Host PC? What you can do is cross compile your stuff first in Host PC and then copy to target file system.
checking for cc…
no
checking for cc…
no
checking for cl…
no
So I wouldn’t be too concerned about awk and more concerned about gcc. If you are compiling on the beagleboard then you will need a native ARM C compiler and probably the best thing to look for would be a pre-built toolchain on gnuarm.
==>>Is any reason you did not do cross-compile in Host PC?
I didnt get the tftp setup, and I have to plug the SD card in and out
which is troublesome, however, I just got tftp setup now, and it
worked well..
==>>If you are compiling on the beagleboard then you will need a
native ARM C
compiler
I tried to pass my compiler through the CC variable, it shows that it
can find the gcc now, but I'm getting another error.. any idea what
can possibly cause this? I got the compiler from http://narcissus.angstrom-distribution.org/
online builder..
checking for a BSD-compatible install... config/install-sh -c
checking whether build environment is sane... yes
checking for gawk... no
checking for mawk... no
checking for nawk... no
checking for awk... awk
checking whether make sets $(MAKE)... no
checking for gcc... arm-angstrom-linux-gnueabi-gcc
checking for C compiler default output file name... configure: error:
C compiler cannot create executables
beagleboard.
==>>opkg update
==>>opkg install task-native-sdk
What does task-native-sdk actually install? where can I find all the
list of stuff that I can install using "opkg install"? Anyway I did
the 2 u mentioned + "opkg install make", and I can use gnu make
now..
if you are used to cross-compiling for ARM on Ubuntu,
could you explain how to configure everything?
i have installed the cross compiler via sudo apt-get install gcc-arm-linux-gnueabi
(don’t know if that is ok for the Angstrom ?)
i’m trying to cross-compile the NTP source code from NTP.org,
which is using autoconf,
but i’m getting an error which i don’t understand:
when i run the configure, it gives me the error:
configure: error: crossing compiling: use --with-yielding_select=yes|no|manual
i added a config.site file including the CC, LDflags and CPPFLAGS to have the correct reference:
CC=arm-linux-gnueabi-gcc-4.7
LDFLAGS=-L/usr/lib/gcc-cross/arm-linux-gnueabi/4.7
CPPFLAGS="-I/usr/lib/gcc-cross/arm-linux-gnueabi/4.7/include -I/usr/lib/gcc-cross/arm-linux-gnueabi/4.7/include-fixed"
and my parameters of my configure look like this:
./configure --host=arm-unknown-linux-gnueabi --build=x86_64-unknown-linux
Is there anything else i need to be able to crosscompile this successfully for Angstrom?
