Help on Pico Projector
I need some help on using Pico projector Discovery 5000. I am currently trying to use with OMAP ZOOM board which has a HDMI out. The board is being succesfully used with HD TV and HDMI monitors. The resolution that I use is 1280 * 720. I am trying to use Pico projector instead of HDTV.
I undetsand that Pico needs an input clock of 27MHz and a resolution of VGA or HVGA. I am trying to understand the other modifications that are needed apart from clock and resolution. I kow that the Pico can function in I2C mode and CPU interface mode. can any one let me know where the configuration for Pico is being done in the kernel source code and in which mode is it being used. Your suggestions would be really helpful.
Kiran
