what is it that i need to do differently in pocketbeagle. This same code
works for my pocket beagle. i have also ensured that my ttyO4 is enabled.
Please clarify "pocketbeagle" vs "pocket beagle"? I suspect you mean
one of the beaglebone black series...
My code is as below. any help would be highly appreciable. Thanks
A Google search reports a BBB showing the same message -- on
StackOverflow, three years ago -- with no answers.
No confirmed answers here either https://groups.google.com/g/beagleboard/c/kBfn3JW2Kao
though I would suggest verifying the /boot/uEnv.txt files on the two
systems you mention, along with checking kernel version, bonescript and
node.js versions.
I tried suppressing the error produced by line 462 by bruteforce (putting is_capemgr as True). and got rid of this error.
however, got stuck with the error in 468 (Device Tree overlay fragment BB-UART4 not loaded).
which means that load_dt fails to fetch the port. i am trying to find out location of load_dt function. hopeful to solve this issue with community help. thanks
load_dt is a relic from kernel overlays.. Just make sure you loaded
the BB-UART4 u-boot overlays and nuke your "var b =
require('bonescript');" as it's not supported/needed/required
anymore..
