Help! Problem with android porting
Hi all,
We are porting android on beagle board.When we try to boot from sd
card,we got the following error..
Failed to execute /init. Attempting defaults...
Kernel panic - not syncing: No init found. Try passing init= option
to kernel.
We are using 64 MB SD Card.We created two partitions:
FAT32 - for uImage
ext3 - for root file system
When we use the pre-built images available from the net,we are
getting the same error.
Please help us...
Log
Morice,
  Are you following it from below link ?
http://labs.embinux.org/index.php/Android_Porting_Guide_to_Beagle_Board
Rupesh,
Yes,we followed the same link...But we are using 64 MB card with 255
heads,40 sectors/track and 12 cylinders.Is it necessary that it has 63
sectors/track??When we use the prebuilt images available from
embinux.com,we are getting the same error.
Please help us...
Thanks in advance,
Morice
Did you actually copy the filesystem to the ext3 partition?
And where did you get the "androidboot.console=ttyS2" part in the boot
arguments? I hadn't come across that before.
Rupesh,
Yes,we are porting beagle board as per the above link...
Now we are getting the following errors,
VFS: Mounted root (ext3 filesystem) on device 179:2.
Freeing init memory: 132K
init: cannot open '/initlogo.rle'
init: cannot find '/system/bin/playmp3', disabling 'bootsound'
Please help..
Thanks in advance,
Morice
Morice,
You can ignore these errors. From above logs i can assume that init is
running on your board.
Can you describe what is problem you are facing now ? Ideally you should
see "ANDROID" string on your LCD after these error messages and Android
desktop screen should appear.
U-Boot environment data should be written such that it can be stored in a single
block (128KB) of the NAND Flash device. so it is necessary to make headers sectors
to 255 abd 63 respectively use 1GB card it may solve u r pproblem.
Regards
BHARATH.S.V
