Help regarding building OpenCV application on QT and deploying in BB
Hi ,
I followed the steps mentioned in the
http://treyweaver.blogspot.com/2010/10/setting-up-qt-development-environment.html
and was able to build QT so that it compiles the programs which can be
run on BB.
In the blog it is mentioned that I should copy the files from opt/qt-
arm/lib to same files on BB.
I am not able to copy the files on to pendrive. Few files with .so
extension are not getting copied.
On the target, i.e BB.
I typed these commands,
the PATH statement in /etc/profile to the following:
PATH="/opt/qt-arm/lib:.....
Connect BeagleBoard to the Internet.
opkg update
opkg upgrade
opkg install g++
opkg install opencv
To get the packages run:
opkg install libgles-omap3
opkg install libstdc++6
opkg install libpng12-0
I copied the executable file to BB.
When I am running the executable file.I am running it I am getting
error.
It says,
expecting "(" but got ")" ---something of this sort.
What can be the problem be?
Can anyone give the steps to follow to build my first program on BB?
Sai
It is recommended to cross-compile your program using openembedded or
install appropriate toolchain.
How did you compiled your program?
I used angstrom toolchain.
2011/12/5 Predrag Manojlović <pedjaman@gmail.com>
I have crosscompiled it for BB.
You should compile you application also on your host computer.
What are the steps ou performed to compile?
From toolchain installation to application compilation
2011/12/4 Sai Manoj Prakhya <saimanoj18@gmail.com>
