Help setting high speed graphic driver on ubuntu for beagle board
I have followed the following wiki to install ubuntu on beagle board
http://elinux.org/BeagleBoardUbuntu
However, when I get to SGX Video Acceleration, things start not to
work properly
I'm using kernel 2.6.28-omap1 and the modules are in the right place
( /lib/modules/2.6.28-omap1/kernel/drivers/char )
Then i make
sudo depmod -a omaplfb
Ok
Then I make
sudo ln -sf /usr/lib/libXdmcp.so.6.0.0 /usr/lib/libXdmcp.so.0
sudo ln -sf /usr/lib/libXau.so.6.0.0 /usr/lib/libXau.so.0
Which goes allright as well.
But I cant start X
If fails saying that no screens are found
Any tips?
Nuno
Hi Nuno,
Couple things to check:
Did you rebuild the modules for 2.6.28? (the modules listed on the
wiki are only built against 2.6.29 oer34+)
What's in your pvr init script?
http://elinux.org/BeagleBoardUbuntu#Startup_Script
What's in your xorg.conf? (
http://elinux.org/BeagleBoardUbuntu#xorg.conf ) 16 bit mode is the
most important. The "Driver "omapfb"" using the omap3 neon optimized
driver or "Driver "fbdev""
