Hello Everyone
Let me first start by saying I am new to the BeagleBone - but I have tried to research as much as I can on how to get ssh to work over usb and I still am having trouble.
I have a BBB, rev A5B, running off of a 4GB flash with distribution Angstrom Distribution (BeagleBone, BeagleBone Black - 4GB SD) 2013-06-20 using a MacOS 10.8.5
I have installed the drivers
FTDI_Ser.dmg
and run the do_patch.sh
and the HoRNDIS-rel4.pkg
that are on the BeagleBone with you plug it in via the usb cable.
I went to the MacOS system preferences ->Network and updated the connection information to be:
Configure IPv4: Manually
IP Address: 192.168.7.2
Subnet Mask: 255.255.255.255 but also tried 255.255.0.0
The Mac says the BeagleBone is connected.
When I try: ssh root@192.168.7.2 I always get ‘ssh: connect to host 192.168.7.2 port 22: Connection refused’
I am able to connect via Ethernet connection.
If you have any suggestions on how to get this to work I would be very grateful.
Thank you in advance for your help.
Pat
