Hi!
I'm trying to measure the time it takes for the BeagleBoard to be put
into suspend to RAM -sleep. The problem is that the time seems to vary
a lot from time to time. If I run my sleeping script several times in
a row it only takes a fraction of the time that it takes if I run a
command (any command) in between. On the other hand, if I modify the
script so that it runs some commands before putting it to sleep it
will still fall to sleep extremely fast.
I started looking at the Linux ACPI code, but I have not really got a
clear view of what causes the variation. I came across a "sys_sync();"
call, which sounds like something that could cause this. The only
thing I've been able to find out about this function is that it "syncs
the file systems".
Does anyone know more about this? What could cause my problem? What
does the ACPI really do to suspend to RAM? What does sys_sync do?
I'm very thankful for any response.
- Jens
