Help with the HMC5883L magnetometer
it seem that I’m able to get the data from the HMC5883L sensor but, the data is weird. The data would gain an increment of of 1 until it turn fully 90 degree then suddenly jump to another number. Here the code can some1 look over it.
var i2c = require('i2c');
var address_compass = 0x1e;
var wire1 = new i2c(address_compass, {device: '/dev/i2c-1'});
var compassData_X = 0;
var compassData_Y = 0;
var compassData_Z = 0;
var compass;
wire1.writeBytes(0x00, [0x70], function(err) {})
wire1.writeBytes(0x01, [0xA0], function(err) {})
wire1.writeBytes(0x02, [0x00], function(err) {})
setInterval(function(){ wire1.readBytes(0x03, 2, functions(err,res){
`compassData_X = res[0] << 8 | res[1] ;`
compassData_Z = res[2] << 8 | res[3] ;
`compassData_Y = res[4] << 8 | res[5];`
console.log("x: " + compassData_X + "y: " + compassData_Y + "z: " + compassData_X ); */
var declinationAngle = .226; //use in compass functions, value needed checking with sensor
var pi = 3.14;
var heading = Math.atan2(compassData_Y,compassData_X);
// Once you have your heading, you must then add your 'Declination Angle', which is the 'Error' of the magnetic field in your location.
//If you cannot find your Declination, comment out this lines, your compass will be slightly off.
heading += declinationAngle;
// Correct for when signs are reversed.
if(heading < 0)
heading += 2*pi;
// Check for wrap due to addition of declination.
else if(heading > 2*pi )
heading -= 2*pi ;
// Convert radians to degrees for readability.
var headingDegrees = ((heading * 180)/pi);
console.log("x: " + compassData_X + " y: " + compassData_Y + " z: " + compassData_Z + " uT"); // Display the results
//(magnetic vector values are in micro-Tesla (uT))
console.log('Heading: ' + headingDegrees + ' degrees' );
})}, 1000)
Thank you,
did it solve the problem?
