It’s been a month now and I have tried everything to transfer a simple file to BBB using TFTP and it seems that BBB can’t find the server.
I am unable to download anything via tftp: below is the snapshot:
U-Boot# setenv ipaddr 192.168.0.100
U-Boot# setenv serverip 192.168.0.1
U-Boot# tftp 0x81000000 hemant.txt
link up on port 0, speed 10, half duplex
Using cpsw device
TFTP from server 192.168.0.1; our IP address is 192.168.0.100
Filename ‘hemant.txt’.
Load address: 0x81000000
Loading: T T T T T T T T T T T T T T T T T T T T
Retry count exceeded; starting again
using musb-hdrc, OUT ep1out IN ep1in STATUS ep2in
MAC d0:39:72:6b:eb:11
HOST MAC de:ad:be:af:00:00
RNDIS ready
musb-hdrc: peripheral reset irq lost!
high speed config #2: 2 mA, Ethernet Gadget, using RNDIS
USB RNDIS network up!
Using usb_ether device
It's been a month now and I have tried everything to transfer a simple file
to BBB using TFTP and it seems that BBB can't find the server.
Using cpsw device
Filename 'hemant.txt'.
RNDIS ready
You need a dhcp server for the dhcp command to get an ip. I've done
this two ways before. One, I've let my router hand out an ip to the
board and two, I've set up a dhcp server on the tftp server but handed
out ips in a completely different, and fixed range.
Thanks for your suggestion. In my virtualbox, I had two network card and your reply made me think which card is used by tftp-hpa.
Since I didn’t find anything, I simply disabled one of the network card not in use and this worked like a charm
