Hi guys,
I've just set-up an angstrom SDK on Ubuntu 11.10 x86_64 and configured
the ARM cross-compiler in Code::Blocks.
However, when compiling a standard template I receive the following
error:
'error while loading shared libraries: libmpfr.so.1: cannot open
shared file: No such file or directory'
Looking for the library in /usr/local/angstrom/arm/arm-angstrom-linux-
gnueabi/usr/lib I can find only libmpfr.so, libmpfr.so.4 and
libmpfr.so.4.0.0. I have attempted to create a symbolic link called
libmpfr.so.1 but this does not help. The directory is in the
Code::Blocks Search Directories -> Linker tab.
I'm unsure where to go from here and would greatly appreciate any
help. I've posted on the angstrom mailing list but it appears
relatively less active and I know there's some angstrom geniuses
around here!
Many thanks,
Alistair
